Some weeks ago I installed my dual extruder to my A350 and did some test prints with dual collores and also some longer prints with only one extruder used.
This weekend I wanted to try the breakaway PLA. I also had some job that would realy profit from it. A simple model that I wanted to print in a certain orientation that would need support.
So far so good I set everything up, started the print. First layers looked good.
After about 1 hour of printing I was wondering why my printer stopped working. The light of the housing was off, the printhead was standing still everything was cold and the touchscreen showed “Machine not responding…”. reconnecting did nothing only a power cycle. I tried it again and the problem came again at the same place.
Coud this be problem with the g-code (done with the lates luban version, EDIT: the updater was not working I was on V4.5.1 not the latest, I will try again with 4.7.3)?
For me it more looks like a problem with the power supply overheating or the machine pulling to much power. But why does it apear exactly after the same time in multiple tries?
I am using V1.15.21 (just manualy downloading .23 now the printer doesn’t seem to “see” the new version) and was printing PETG (@235°C) and breakaway PLA (@220°C) printbed temp was set to 65°C.
If the power is the problem then the specs are not chosen good enough I would expect to theoreticly print with 300-300-80.
Did some ever expirienced an equal problem?
I generated a fresh g-code with the latest 4.7. Version of luban. Now it stoped after 5 hours printing at 90%.
This module is totaly unreliable and a waste of money.
I got a “Machine not responding” error shortly after I plugged the dual extruder in. I can’t remember if that was before or after I had to switch back to the original extruder to boot far enough to upgrade the firmware.
I haven’t seen any failures since, though, and that failure was at first boot, not while the unit was in operation.
In your case, it sounds like there’s some command in your G-code that is causing some component of the system to hang or crash. Your best bet is probably to reach out to Snapmaker support and provide them with a copy of the G-code so that they can figure out what’s going on.
Or it could be a loose toolhead cable that gets pulled loose at the same spot in the G-code for the same reason. Doubtful, but worth checking. ![]()
Also, don’t bother with V1.15.22 or V1.15.23. The release notes weren’t anything related to printing.
- 1.15.22 added info about the active Wi-Fi network and fixed a bug that can cause it to disconnect immediately whenever you connect remotely.
- 1.15.23 added RSSI info about Wi-Fi networks.
I’m pretty sure neither of those is relevant.
Checking the cables was the first I have done after the initial failure. Writing a support ticket with the g-code was the second thing after I found out it was reproduceble.
So I hope I will get some solution for that.
You will have to share your logs, maybe post here with tripple backticks before and after?
Here is the log part that should show the error. The error must have happend at the last log entry from 23.04.
In the morning (first entry from 24.04.) I reconnected the touchscreen and tried to pause the job, what also failed with an error.
In the error state everything was off (head not moving and sitting on the moddel, hotends and bed cold, fans and enclosure light off) except the power supply.
1682288668880,2023.04.23 22:24:28.880,INFO,SC-FW,Set T0=209
1682288668882,2023.04.23 22:24:28.882,INFO,SC-FW,new E target temp: 215
1682288668884,2023.04.23 22:24:28.884,INFO,SC-FW,Set T1=215
1682288668886,2023.04.23 22:24:28.886,INFO,SC-FW,fan_index: 1, speed: 255
1682288668888,2023.04.23 22:24:28.888,INFO,SC-FW,new E target temp: 220
1682288668891,2023.04.23 22:24:28.891,INFO,SC-FW,Set T1=220
1682288676451,2023.04.23 22:24:36.451,INFO,SC-FW,new E target temp: 230
1682288676459,2023.04.23 22:24:36.459,INFO,SC-FW,Set T0=230
1682288688392,2023.04.23 22:24:48.392,INFO,SC-FW,new E target temp: 215
1682288688398,2023.04.23 22:24:48.398,INFO,SC-FW,Set T1=215
1682288694211,2023.04.23 22:24:54.211,INFO,SC-FW,leveling OFF
1682288694217,2023.04.23 22:24:54.217,INFO,SC-FW,origin pos: 221.709, 264.244, 79.956
1682288694219,2023.04.23 22:24:54.219,INFO,SC-FW,raise: 1.000, endstop max: 332.596, z offset: -1.404
1682288694490,2023.04.23 22:24:54.490,INFO,SC-FW,raised pos: 221.709, 264.244, 80.956
1682288694682,2023.04.23 22:24:54.682,INFO,SC-FW,Unapply hotend[1] Z offset: 0.25
1682288696098,2023.04.23 22:24:56.098,INFO,SC-FW,offset pos: 195.790, 264.088, 82.359
1682288696945,2023.04.23 22:24:56.945,INFO,SC-FW,Apply hotend[0] Z offset: 0.25
1682288697243,2023.04.23 22:24:57.243,INFO,SC-FW,descent pos: 221.709, 264.244, 79.956
1682288697244,2023.04.23 22:24:57.244,INFO,SC-FW,leveling ON
1682288697245,2023.04.23 22:24:57.245,INFO,SC-FW,new E target temp: 150
1682288697246,2023.04.23 22:24:57.246,INFO,SC-FW,Set T1=150
1682288697247,2023.04.23 22:24:57.247,INFO,SC-FW,new E target temp: 230
1682288697257,2023.04.23 22:24:57.257,INFO,SC-FW,Set T0=230
1682288697258,2023.04.23 22:24:57.258,INFO,SC-FW,fan_index: 0, speed: 127
1682288697259,2023.04.23 22:24:57.259,INFO,SC-FW,new E target temp: 235
1682288697260,2023.04.23 22:24:57.260,INFO,SC-FW,Set T0=235
1682311752943,2023.04.24 04:49:12.943,INFO,SC-FW,SC req PAUSE
1682311752944,2023.04.24 04:49:12.944,WARN,SC-FW,cannot pause in current status: 1
1682311752945,2023.04.24 04:49:12.945,INFO,SC-FW,SC req → Failed
39018,1970.01.01 00:00:39.018,INFO,SC-FW,Created marlin task!
39043,1970.01.01 00:00:39.043,INFO,SC-FW,SC req Exception
39134,1970.01.01 00:00:39.134,INFO,SC-FW,SC req enclosure sta
39136,1970.01.01 00:00:39.136,INFO,SC-FW,Eclosure: set LIGHT power 100
39140,1970.01.01 00:00:39.140,INFO,SC-FW,SC req emergency stop sta:1
39143,1970.01.01 00:00:39.143,INFO,SC-FW,SC req rotate sta:1
39649,1970.01.01 00:00:39.649,ERROR,SC-FW,purifier info update timeout:0 - 2!
39651,1970.01.01 00:00:39.651,INFO,SC-FW,SC req purifier sta:1, err:0x0
39654,1970.01.01 00:00:39.654,INFO,SC-FW,active_probe_sensor: 0
39656,1970.01.01 00:00:39.656,INFO,SC-FW,hotend_type: 0: 1, 1: 1
39666,1970.01.01 00:00:39.666,INFO,SC-FW,hotend_diameter: 0: 0.40, 1:0.40
39668,1970.01.01 00:00:39.668,INFO,SC-FW,Kp: 150.000, Ki: 1.000, Kd: 30000.000
39669,1970.01.01 00:00:39.669,INFO,SC-FW,z_compensation: 0: 0.538, 1: 0.457
39728,1970.01.01 00:00:39.728,INFO,SC-FW,live Z offset 0: 0.25, 1: 0.25
40646,1970.01.01 00:00:40.646,ERROR,SC-FW,purifier info update timeout:0 - 2!
40648,1970.01.01 00:00:40.648,INFO,SC-FW,SC req purifier sta:1, err:0x0
1682311938627,2023.04.24 04:52:18.627,INFO,SC-FW,leveling OFF
1682311976960,2023.04.24 04:52:56.960,INFO,SC-FW,leveling ON
1682311977159,2023.04.24 04:52:57.159,INFO,SC-FW,Apply hotend[0] Z offset: 0.25
Edit, here is the other log at the same time:
1682288743486,2023.04.23 22:25:43.486,DEBUG,SC,batchGcodeResponse Request LineNo:388600
1682288743537,2023.04.23 22:25:43.537,DEBUG,SC,batchGcodeResponse Request LineNo:388602
1682288744719,2023.04.23 22:25:44.719,WARN,SC,Not getting machine status, replace with default status.
1682288745720,2023.04.23 22:25:45.720,WARN,SC,Not getting machine status, replace with default status.
1682288746719,2023.04.23 22:25:46.719,WARN,SC,Not getting machine status, replace with default status.
1682288747725,2023.04.23 22:25:47.725,WARN,SC,Not getting machine status, replace with default status.
1682288748718,2023.04.23 22:25:48.718,WARN,SC,Not getting machine status, replace with default status.
1682288749721,2023.04.23 22:25:49.721,WARN,SC,Not getting machine status, replace with default status.
1682288750719,2023.04.23 22:25:50.719,WARN,SC,Not getting machine status, replace with default status.
1682288751720,2023.04.23 22:25:51.720,WARN,SC,Not getting machine status, replace with default status.
1682288751723,2023.04.23 22:25:51.723,INFO,SC,onConnection, connected = false
1682288751725,2023.04.23 22:25:51.725,WARN,SC,Loss connection from machine.
1682288751735,2023.04.23 22:25:51.735,INFO,SC,Disable heartbeat.
1682304925839,2023.04.24 02:55:25.839,DEBUG,SC,Wi-Fi connected.
1682311695077,2023.04.24 04:48:15.077,INFO,SC,Try to reconnect machine…
1682311695084,2023.04.24 04:48:15.084,DEBUG,SC,Request 0x09 0x14
1682311695085,2023.04.24 04:48:15.085,DEBUG,SC,Requesting module info…
1682311695088,2023.04.24 04:48:15.088,DEBUG,SC,G-code Request Hex: AA 55 00 0A 01 0A 9D 4D 01 00 00 00 00 4D 31 30 30 35
1682311695090,2023.04.24 04:48:15.090,INFO,SC,onConnection, connected = true
1682311695094,2023.04.24 04:48:15.094,INFO,SC,Enable heartbeat.
1682311695585,2023.04.24 04:48:15.585,DEBUG,SC,Retry with delay number:1
1682311696117,2023.04.24 04:48:16.117,DEBUG,SC,Head type 5 found.
1682311696591,2023.04.24 04:48:16.591,DEBUG,SC,Request 0x09 0x14
1682311696610,2023.04.24 04:48:16.610,DEBUG,SC,Response 0x0a 0x14
1682311696611,2023.04.24 04:48:16.611,DEBUG,SC,Found emitter disposed, skip.
1682311696614,2023.04.24 04:48:16.614,DEBUG,SC,Machine model 3, size x 358 y 358 z 334
1682311752911,2023.04.24 04:49:12.911,INFO,SC,Pause print.
1682311752948,2023.04.24 04:49:12.948,WARN,SC,Unable to pause printing.
37794,1970.01.01 00:00:37.794,INFO,SC,Application started!
37796,1970.01.01 00:00:37.796,DEBUG,SC,Build SDK version: 25
37800,1970.01.01 00:00:37.800,DEBUG,SC,FabScreen version: V1.15.14
38962,1970.01.01 00:00:38.962,DEBUG,SC,HTTP server started.
38964,1970.01.01 00:00:38.964,INFO,SC,Connecting serial port…
39010,1970.01.01 00:00:39.010,DEBUG,SC,Request 0x09 0x14
39020,1970.01.01 00:00:39.020,DEBUG,SC,Requesting module info…
39024,1970.01.01 00:00:39.024,DEBUG,SC,G-code Request Hex: AA 55 00 0A 01 0A 9D 4D 01 00 00 00 00 4D 31 30 30 35
39035,1970.01.01 00:00:39.035,DEBUG,SC,Response 0x0a 0x14
39037,1970.01.01 00:00:39.037,DEBUG,SC,Machine model 3, size x 358 y 358 z 334
39039,1970.01.01 00:00:39.039,INFO,SC,onConnection, connected = true
39041,1970.01.01 00:00:39.041,INFO,SC,Enable heartbeat.
39053,1970.01.01 00:00:39.053,WARN,SC,Module 0x0C version (v1.13.12�,��) is invalid!
39061,1970.01.01 00:00:39.061,WARN,SC,Module 0x0C version (v1.13.12�,��) is invalid!
39069,1970.01.01 00:00:39.069,WARN,SC,Module 0x05 version (v1.13.12�,��) is invalid!
39084,1970.01.01 00:00:39.084,WARN,SC,Module 0x0C version (v1.13.12�,��) is invalid!
39093,1970.01.01 00:00:39.093,WARN,SC,Module 0x0C version (v1.13.12�,��) is invalid!
39103,1970.01.01 00:00:39.103,WARN,SC,Module 0x0C version (v1.13.12�,��) is invalid!
39111,1970.01.01 00:00:39.111,WARN,SC,Module 0x0D version (v1.13.12�,��) is invalid!
39138,1970.01.01 00:00:39.138,DEBUG,SC,Set Enclosure lighting true
39217,1970.01.01 00:00:39.217,DEBUG,SC,M1005
Marlin SM2-4.5.34
Compiled: Mar 9 2023, 17:08:07
PACKAGE: Snapmaker_V4.5.34
Module Ver:
Module 0x00C27B52: v1.13.12
Module 0x00C27B78: v1.13.12
Module 0x00509546: v1.13.12
Module 0x00C84F3C: v1.13.12
Module 0x00C84F48: v1.13.12
Module 0x00C84F4C: v1.13.12
Module 0x00D01B4A: v1.13.12
linear_tmc X1 length: 356 mm, lead: 20 mm
linear_tmc Y1 length: 356 mm, lead: 20 mm
linear_tmc Z1 length: 356 mm, lead: 8 mm
linear_tmc Y2 length: 356 mm, lead: 20 mm
linear_tmc Z2 length: 356 mm, lead: 8 mm
Machine Size: L
ok
39225,1970.01.01 00:00:39.225,DEBUG,SC,G-code Request Hex: AA 55 00 0A 01 0A 9D 4C 01 00 00 00 00 4D 31 30 30 36
39677,1970.01.01 00:00:39.677,DEBUG,SC,M1006
Tool Head: 3DP
echo:Hotend offsets: 0.00,0.00,0.000 25.92,0.16,-1.404
ok
I am not so familiar with this logs but i guess the error appeared in the past of 22:24:28.880 your first log.
I see you tried to adjust the temperature and it may not work anymore?
In the second log the hotend was displaced for two seconds?
Are you on the latest firmware and update was ok?
