Specific file wont stick to bed
I have a specific file that won’t stick to the bed. Everything else sticks and prints fine and I can’t figure out what’s wrong with this file. I have done recalibration, bed cleaning, glue on the base.
I built in in Fusion 360 and I have a A350.
Thats a big print, has to be placed diagonally on the bed and uses all of it Are the prints that work as big?
I dont think there is anything wrong with the file I get a later 1 thats over the complete model which should stick down well as long as your bed is level. I think you have a bed leveling issue and the only thing I can suggest is you run through some of the large number of bed leveling posts in the forum.
indeed. the snapmaker is very difficult to overcome the poor flatness and it requires a lot of patience, practice and tinkering to get to a point where you know your particular bed and how to overcome.
this is not a big deal on smaller parts usually but it can be on big ones.
to me that looks like a challening part all the way around. those rods are gona be tough to get to look good, they also might not be particularly durable…
might be better off having a hole there and securing a metal rod with a nut or something from the back, but give it a whirl!
So turns out you were absolutely correct. A) my bed was installed upside down. B) was way off level. ended up turning it into a 7x7 auto level and adjusting from there. Its printing quite nicely now.
Thank for your help!
