SnapScreen — KlipperScreen on Steroids, Built for the Snapmaker U1
I have read and understood all rules of the Innovation Fund Phase 2
on
I consent to my project information (username, project cover, summary, etc.) being publicly displayed for review and showcase
on
Username (for public display)
Damian Borkowski / Alpha Studio
Project name
SnapScreen
Project URL
Project cover
Project Category
Accessory
Project Summary
I built SnapScreen because I want the screen beside my U1 to do more than show a progress bar. I want to see all four tools, inspect the file, manage native filaments and arrange the information around the way I actually work.
SnapScreen is my free, dedicated ESP32-P4 touchscreen workstation for the Snapmaker U1. “KlipperScreen on steroids” describes the idea: it is an independent embedded application, not KlipperScreen renamed or a Linux installation on another computer. The panel runs its own interface and communicates with the U1 through its local API, without replacing the printer firmware or requiring a Raspberry Pi to host the screen.
The main features are:
• Customizable widget dashboards with touch-and-hold editing, a visual widget library, selectable sizes and alternative presentations.
• Four-hotend monitoring, thermal history, bed/chamber readings, temperature controls, cooling and speed/flow overrides.
• XYZ movement, homing, step sizes, extrusion and Z-offset controls where supported by the printer configuration.
• Printer file browsing and an interactive G-code viewer with 3D toolpaths, model details, feature/tool filters, rotation, pan, zoom and lighting.
• A print monitor combining progress, ETA, layers, a 2D/3D preview and four native spools with material names, printer-supplied colors and active-filament paths.
• A dedicated Filaments workspace for the U1’s own four tools, including color/HEX and load/unload workflow controls.
• Camera viewing on stock and Paxx firmware, with zoom in/out and pan. A lightweight adaptive algorithm adjusts the timing of the next snapshot request based on fresh/repeated frames and failed requests, aiming for smoother viewing and a higher effective FPS without unnecessary polling.
• Enhanced cold/hot bed leveling with 2D/3D mesh inspection. An optimization algorithm calculates screw corrections from measured mesh data; live guidance shows which screw to turn and in which direction, where supported by printer firmware. It flags further predicted improvements, aiming for the best achievable result on that individual bed.
• Printer macros and a built-in G-code terminal with intelligent command suggestions.
• Independent icon families, interface tones and dark/light mode.
There is already a public dual-P4 installation kit with automatic revision selection, free network/offline installation and English/Polish panel-only build guides. The latest 1.0.10 interface has been installed on my older-P4 panel. The screenshots are actual hardware-rendered captures; the showcased print/mesh values use an isolated presentation source and are not evidence that a physical print or calibration was completed. New-P4 display, touch and network installation were reported working by a beta tester on an earlier build; acceptance of the latest UI on that family remains separate.
SnapScreen is free and does not require an activation payment. Builders supply the panel hardware. PrismFlow is the separate activated product for external filament-changer integration; those changer features are not part of this entry.
I am applying to the Cash Fund to improve reproducible assembly, compatibility testing, real-printer validation, documentation and the first-install experience. My aim is a capable U1 companion panel that other owners can build and use themselves.
Project, downloads and guides: GitHub - AlphaStudioDE/SnapScreen: Free SnapScreen touchscreen panel for Snapmaker U1. Public downloads and documentation; no activation required. · GitHub
Actual-panel gallery and feature reference: SnapScreen/docs/SCREENSHOT-GALLERY.md at main · AlphaStudioDE/SnapScreen · GitHub
Open Source Status
Closed Source
Please specify the open source license used by this project
N/A — currently closed source and free to use. I plan to release the source code under an open-source license after the competition ends. Until then, I am keeping the source private to protect my original solutions from being copied and used in competing entries without my permission. Third-party dependencies retain their respective licenses.
Cash Fund or U1 Hardware Sponsorship
Cash Fund
Originality
Original New Idea
If based on an existing project — your independent contribution
SnapScreen is my original project, designed and developed specifically for the Snapmaker U1. I created its touchscreen interface, customizable widget system, printer integration, G-code visualization, filament management, camera controls and assisted bed-leveling workflows.
My work also includes the embedded firmware, support for both ESP32-P4 hardware revisions, and an installer that automatically selects the appropriate firmware. SnapScreen runs as a standalone touchscreen panel and extends the U1’s capabilities without replacing the printer firmware.
SnapScreen is free to use. Project, downloads and build instructions: GitHub - AlphaStudioDE/SnapScreen: Free SnapScreen touchscreen panel for Snapmaker U1. Public downloads and documentation; no activation required. · GitHub
Is it a paid project?
No
A closer look at SnapScreen — the features I wanted beside my U1
I wanted a panel that makes the U1 easier to understand and more comfortable to use every day. Here is what I have built so far, with screenshots taken directly from my ESP32-P4 panel.
Your print, all four tools, one clear view
I want to see what the printer is doing without jumping between several pages. Printing brings together progress, remaining time, layers, temperatures and a 2D/3D preview. The four large spools show the printer’s material names and colors, with a colored path identifying the filament currently in use. An unavailable spool is greyed out, so the screen reflects the printer’s state.
Filaments — give each tool its own place
I gave the U1’s four native filaments a dedicated workspace. Select a spool to see its material and tool information, change its color using the color picker or HEX value, and access loading and unloading controls. Color changes are sent back to the printer. My aim is to make managing four tools feel straightforward, with the selected spool and its controls together on one page.
Build the dashboard around the way you print
I do not want every owner to be stuck with my preferred layout. Touch and hold to edit a dashboard, move widgets and choose their sizes and presentations. The visual widget library lets you see what you are adding. Put the information you care about where you want it: temperatures, motion, print progress, previews or shortcuts. Different pages can serve different jobs.
Look inside the G-code before pressing Print
A filename and a small thumbnail do not always tell me enough. My interactive G-code viewer lets you inspect the toolpaths on the panel itself. Rotate, pan and zoom the model, change the lighting, and filter features or tools to understand how the file was sliced. File browsing and model details are available alongside it, so you can take a closer look without returning to your computer.
Bed leveling that helps you decide what to do next
I wanted more than a colorful mesh. SnapScreen offers cold and heated leveling workflows, together with 2D/3D views of the bed surface. A small optimization algorithm uses the measured mesh to calculate screw corrections, aiming for the best achievable result on that individual bed.
Live guidance shows which screw to turn and in which direction, when supported by the printer firmware. If further adjustment can meaningfully improve the predicted result, the algorithm indicates it. The goal is to get the most out of mechanical leveling while recognizing that screws cannot remove every irregularity in the surface.
See how all four hotends behave
Four tools deserve more than four temperature numbers. Temperature history helps you see how the hotends behave over time, alongside heater controls, bed/chamber readings, cooling and speed/flow overrides. I want the information and the relevant controls close together, whether I am preparing a print or checking something that does not look right.
Hands-on control when you need it
Jog the axes, choose movement steps, check coordinates and home the printer from the panel. Additional motion pages provide extrusion, Z-offset and related controls where supported by the printer configuration. These are the practical tools I want within reach when preparing the machine or working through a problem.
Your macros and a terminal with intelligent suggestions
SnapScreen reads the available macros from the printer and presents them on the touchscreen. I want the shortcuts already available on the machine to be useful from the panel too, without having to type each command manually.
Sometimes the quickest route is a direct command. The built-in G-code terminal lets you send commands to the printer and see its responses. Intelligent suggestions help you find commands while typing, making the terminal more convenient for diagnostics and functions beyond the touchscreen buttons. You can stay at the printer instead of opening another application just to use its console.
A panel that can look like yours
Icon families, interface colors and dark/light mode can be selected independently. These screenshots use Satin Ribbon with Blue in dark mode. I prepare the icon assets at their native sizes, with reduced palettes and compression, to keep the interface practical for an ESP32 as well as pleasant to look at.
Camera controls include zooming in, zooming out and panning around the image. I also added a lightweight adaptive algorithm that adjusts when the next snapshot is requested: it speeds up as fresh frames arrive, backs off when frames repeat and allows more time after failed requests. The aim is a smoother preview and a higher effective FPS without wasting requests. Actual performance depends on the camera source and connection.
These are real panel-rendered screenshots of my latest 1.0.10 interface. Print and mesh values were supplied by an isolated presentation source to show the layouts; the images do not document a completed physical print or calibration. Printer-dependent controls require the corresponding firmware support. The public installation kit currently linked in the repository is 1.0.8.
SnapScreen is free to use. You supply the panel hardware; the project includes build instructions and an installer that chooses the appropriate firmware for the supported P4 revision. It works alongside the U1 without replacing its firmware.
Project, downloads and build instructions · Full gallery — 29 distinct views
A quick note about the names: If you followed my earlier updates, the project for connecting filament changers from different manufacturers was previously presented under the SnapScreen name. That project is now called PrismFlow, and I will submit it to the competition separately later.
SnapScreen is my free touchscreen device dedicated to the Snapmaker U1 — built with one ambition: to be the best KlipperScreen-style companion for this printer.
