I’m trying to get Snapmaker 3.4.2 running. I’m using Manjaro Linux. I’m able to load stl files but when starting to slice it immediatly stops. Her an output from the console:
[cs@desktop Snapmaker Luban]$ ./snapmaker-luban
Clearing folder /home/cs/.config/snapmaker-luban/Tmp
Removing files:
Clearing folder /home/cs/.config/snapmaker-luban/Sessions
Removing files:
2020-05-14T07:55:35.056Z - info init Loading configuration from “/home/cs/.snapmaker-luban.json”
2020-05-14T07:55:35.058Z - info server:DataStorage Clearing folder /home/cs/.config/snapmaker-luban/Tmp
2020-05-14T07:55:35.058Z - info server:DataStorage Removing files:
2020-05-14T07:55:35.059Z - info server:DataStorage Clearing folder /home/cs/.config/snapmaker-luban/Sessions
2020-05-14T07:55:35.059Z - info server:DataStorage Removing files:
2020-05-14T07:55:35.184Z - info init Starting the server at http://127.0.0.1:36075
2020-05-14T07:55:35.212Z - info init Starting the server at http://127.0.1.1:36075
2020-05-14T07:55:35.551Z - info server:DataStorage 3.4.2
2020-05-14T07:55:56.591Z - info print3d-slice slice progress closed with code 127
