I just downloaded the latest Luban, and it is not able to slice. I’m using it on a linux system, and I launched it from the terminal. I load my stl, then choose my settings, and click on slice – it hangs at 0.0%. When I refer back to the terminal, I see these errors:
2020-06-17T15:54:17.205Z - error uncaughtException: spawn EACCES
Error: spawn EACCES
at _errnoException (util.js:1024:11)
at ChildProcess.spawn (internal/child_process.js:323:11)
at Object.exports.spawn (child_process.js:514:9)
at so (/opt/snapmaker-luban-3.5.0-linux-x64/resources/app/server/index.js:1:248084)
at uo (/opt/snapmaker-luban-3.5.0-linux-x64/resources/app/server/index.js:1:250267)
at Socket.<anonymous> (/opt/snapmaker-luban-3.5.0-linux-x64/resources/app/server/index.js:1:31534)
at emitOne (events.js:116:13)
at Socket.emit (events.js:211:7)
at /opt/snapmaker-luban-3.5.0-linux-x64/resources/app/node_modules/socket.io/lib/socket.js:528:12
at _combinedTickCallback (internal/process/next_tick.js:131:7)
at process._tickCallback (internal/process/next_tick.js:180:9)
2020-06-17T15:54:17.207Z - error: uncaughtException: spawn EACCES date=Wed Jun 17 2020 11:54:17 GMT-0400 (EDT), pid=26048, uid=1000, gid=1000, cwd=/opt/snapmaker-luban-3.5.0-linux-x64/resources/app/server, execPath=/opt/snapmaker-luban-3.5.0-linux-x64/snapmaker-luban, version=v8.9.3, argv=[/opt/snapmaker-luban-3.5.0-linux-x64/snapmaker-luban], rss=185081856, heapTotal=58822656, heapUsed=51845800, external=812748, loadavg=[1.05859375, 1.14013671875, 1.10693359375], uptime=450072, trace=[column=11, file=util.js, function=_errnoException, line=1024, method=null, native=false, column=11, file=internal/child_process.js, function=ChildProcess.spawn, line=323, method=spawn, native=false, column=9, file=child_process.js, function=Object.exports.spawn, line=514, method=spawn, native=false, column=248084, file=/opt/snapmaker-luban-3.5.0-linux-x64/resources/app/server/index.js, function=so, line=1, method=null, native=false, column=250267, file=/opt/snapmaker-luban-3.5.0-linux-x64/resources/app/server/index.js, function=uo, line=1, method=null, native=false, column=31534, file=/opt/snapmaker-luban-3.5.0-linux-x64/resources/app/server/index.js, function=null, line=1, method=null, native=false, column=13, file=events.js, function=emitOne, line=116, method=null, native=false, column=7, file=events.js, function=Socket.emit, line=211, method=emit, native=false, column=12, file=/opt/snapmaker-luban-3.5.0-linux-x64/resources/app/node_modules/socket.io/lib/socket.js, function=null, line=528, method=null, native=false, column=7, file=internal/process/next_tick.js, function=_combinedTickCallback, line=131, method=null, native=false, column=9, file=internal/process/next_tick.js, function=process._tickCallback, line=180, method=_tickCallback, native=false], stack=[Error: spawn EACCES, at _errnoException (util.js:1024:11), at ChildProcess.spawn (internal/child_process.js:323:11), at Object.exports.spawn (child_process.js:514:9), at so (/opt/snapmaker-luban-3.5.0-linux-x64/resources/app/server/index.js:1:248084), at uo (/opt/snapmaker-luban-3.5.0-linux-x64/resources/app/server/index.js:1:250267), at Socket.<anonymous> (/opt/snapmaker-luban-3.5.0-linux-x64/resources/app/server/index.js:1:31534), at emitOne (events.js:116:13), at Socket.emit (events.js:211:7), at /opt/snapmaker-luban-3.5.0-linux-x64/resources/app/node_modules/socket.io/lib/socket.js:528:12, at _combinedTickCallback (internal/process/next_tick.js:131:7), at process._tickCallback (internal/process/next_tick.js:180:9)]
I noticed that, in the tarball, none of the executables were set to 755 perms, Obviously snapmaker-luban requires this, but I don’t know about anything else in there… perhaps that is the source of my problems? Maybe it is completely unrelated. Anyway, it isn’t working…
Thank you.
-mg
