I bought the snapmaker 2.0 2 month ago. Now i testet the 2 laser modules an I have an issue it
I capture the table. Then I add the Laser motive on it. When I go into the work area, the motive is in a completely wrong position. Also the laser would laser it on a wrong position.
Hi. Do you configured the correct machine type in luban? I have the same problem when I miss to change the machine when switching from one snapmaker to a different one.
You are not following the directions EXACTLY as they are stated. It’s been a while since I’ve used the Laser, so I don’t remember exactly what it is that you are not following correctly, but it’s like 1 or 2 steps that you are not following EXACTLY as written. Go back do everything as written, word for word, don’t change anything.
