I’m having so many issues with my snapmaker. Can anyone give me a simple getting started list. My pc and the snapmaker are seperate rooms. Thanks in advance.
Now the machine is saying “toolhead not found”
Double check your cabling. “Toolhead not found” means the controller can’t talk to the toolhead. Be careful when you’re re-plugging cables: it’s possible to plug the cables in backwards, and that will fry both the toolhead and the controller.
Once you get the tool head to respond, following the setup instructions. After that, I recommend xchrisd’s guide.
