Hi there,
just discovered a bug. If you print via USB Stick and adjust e.g. heatbed temperature on the screen and start to print, it transfers the file AFTER you did the adjustments, therefore overwriting them.
The File should either be transferred first, or the changes should be saved.
Thanks and regards
Marco
