Snapmaker 2.0 will not connect over wifi
I have a 2.0 with quick swap kit and have been using it completely normally for 2 years. Now I get a new computer, and the thing won’t connect to the Luban on the new computer. I’ve tried factory resetting with dev mode on the machine and I’ve tried manually connecting with the machine IP address (which just says “connecting” forever). The only thing that works is the cable, but it would be severely inconvenient to use all the time.
Please help.
Is it the same WiFi it’s connected to?
My router has multiple access points, 2.4G and 5G for example and I’m sure it does not work to connect if they are connected to different access points.
Welp, weird thing happened, it just decided to connect by itself, and I didn’t even do anything :man_shrugging:. If it happens again, I will definitely try to switch bands. Thanks anyway!
