Oct 25 2023: Snapmaker2_V1.18.0
Thank you for your suggestions on how to make the Snapmaker 2.0 better. Your feedback is always appreciated. Here comes the latest version of the Snapmaker 2.0 firmware.
Changelog
Touchscreen
New Features
- Refactor Touchscreen Print Job Management
- In the previous version, when disconnected from Snapmaker Luban during print job, Touchscreen will request stop print job, and could not control the print job until reconnected from Luban.
- In this version, when disconnected from Snapmaker Luban, Touchscreen will return to print. Print job control, power loss recovery and filament detection will recover on Touchscreen.
- Added new Run Boundary Mode for 20W/40W Laser Module
- Crosshairs Mode and Working Laser Mode
Bug Fixes
- Fixed a bug that Touchscreen could not adjusted temperature and load filament when filament ran out during print
- Fixed a bug that guide procedure did not finished correctly when using 10W Laser Module and Rotary Module
- Fixed a bug that Touchscreen could not adjusted B Axis origin when using 20W/40W Laser Module and Rotary Module
- Fixed a bug that Touchscreen showed wrong elapsed time in some scenario
Improvements
- Improved Touchscreen UI/UX with Dual Extrusion 3D Printing Module and Quick Swap Kit
- Optimized Toucreen processing for file transfer and upgrade when local storage is low
- Notice: When local storage is low or insufficient, Touchscreen will clean up local files for free up enough space (according to the file created time locally, from earliest to latest).
Mainboard
New Features
- M3/M4 Gcode update
- Support for M3/M4 to turn Trapizoid Power on or off (in Marlin definition). This differs from standard Marlin, which configures
LASER_POWER_TRAPwhen compiling firmware. The M3/M4 definition will now favor grbl. - Marlin’s M3 I and M4 I switching between Continuous Inline Mode and Dynamic Inline Mode is currently not supported. It is important to note that Marlin’s definition of Dynamic Inline Mode is not the same as Grbl’s definition of Dynamic Laser Power Mode.
- G0/G1 Gcode update
- In both
M3andM4, the laser is turned off when using the G0 movement. - Both Marlin and GRBL types of Inline Mode.
- In both
Module
Bug Fixes
- Fixed a bug that flame sensor triggered on boot up unexpectedly in 20W/40W Laser Module
Downloads
MD5: d5993475a8b25d63eb356623b661cb50
Notes
- This firmware update is only compatible with Snapmaker 2.0.
- To see your current firmware version, go to Settings > About Machine .
How to Update Firmware
- Via a USB flash drive
- Put the firmware update file Snapmaker2_V{version}.bin in your USB flash drive.
- Plug the drive into the Controller.
- On the Touchscreen, tap Files > USB > Snapmaker2_V{version}.bin.
- Via Wi-Fi
- On the Touchscreen, tap Settings > Firmware Update.
- Read the changelog and download the firmware.
- After the firmware is downloaded, tap Update Now.
