Thank you for your suggestions on how to make the Snapmaker 2.0 better. Your feedback is always appreciated. Here comes the latest version of the Snapmaker 2.0 firmware.
Changelog
Controller
Bug Fixes
Fixed a bug that live Z offset calculated incorrectly when go printing immediately after leveling
Touchscreen
Bug Fixes
Fixed a bug that the nozzle temperature adjust widget will point at the first time when printing
Fixed a bug that Touchscreen showed wrong add-on status while Dual Extrusion 3D Printing Module plugged
Fixed a bug that pre-heated option didn’t show up when switching to nozzle page when using Dual Extrusion 3D Printing Module
Changelog
Controller
Bug Fixes
Fixed firmware watchdog to prevent firmware unexpected halt on boot
Fixed a bug that Sensor Calibration could not start when firmware parameters are lost in some scenario
Improvement
Improved valid value check of nozzle temperature in 3D Printing
Improved exception error report in Dual Extrusion 3D Printing Module
Touchscreen
Bug Fixes
Fixed a bug that overrides the right nozzle temperature during printing causes unexpected target temperature
Improvement
Changelog
Controller
Bug Fixes
Fixed a bug that Laser Camera Capture result shifted when using Snapmaker 2.0 A350 model
Improvement
Improved Dual Extrusion 3D Printing module initialization information data received to prevent not getting the right extruder offset value
Changelog
Controller
Bug Fixes
Fixed a bug that hotend fan had stopped unexpectedly in some scenario
Touchscreen
Bug Fixes
Fixed minor wrong description in Dual Extrusion 3D Printing Module Feature.
Changelog
Touchscreen
New Features
Added display of Wi-Fi AP information
In Settings > Wi-Fi, connected AP networks will have an info icon, which when clicked, will display current network information
Bug Fixes
Fixed the issue where the screen disconnects immediately during remote connection in certain scenarios
Changelog
Touchscreen
New Features
Added RSSI value display (signal sensitivity) in Wi-Fi network information
Changelog
Touchscreen
New Features
Added retraction warning if G-code retraction distance was not recommended in Dual Extrusion 3D Printing Module
Bug Fixes
Fixed a bug that adjusting the Initial Layer nozzle temperature and heated bed temperature failed in 3D Printing
Controller
New Features
Added “C” and “W” custom parameter support with “M109” G-code
Improvement
Reduced retraction distance when pausing in 3D Printing job
Changelog
Touchscreen
New Features
Added Quick Swap Kit support
Improvements
Improved remaining storage checks when choosing a file in Touchscreen
Improved initial temperature parsing and applying logic in Touchscreen
Controller
New Features
Bug Fixes
Fixed a bug that the 3D Printing tool head cooling fan was unexpectedly off when recovering from power loss
Changelog
Touchscreen
Bug Fixes
Fixed a bug that Luban couldn’t switch extruder when was connected to Touchscreen
Fixed a bug that G-code paramenters were replaced when parsing G-code file.
Changelog
Touchscreen
New Features
Added 20W Laser Module and 40W Laser Module support
Mainboard
New Features
Module
New Features
Changelog
Touchscreen
New Features
Refactor Touchscreen Print Job Management
In the previous version, when disconnected from Snapmaker Luban during print job, Touchscreen will request stop print job, and could not control the print job until reconnected from Luban.
In this version, when disconnected from Snapmaker Luban, Touchscreen will return to print. Print job control, power loss recovery and filament detection will recover on Touchscreen.
Added new Run Boundary Mode for 20W/40W Laser Module
Crosshairs Mode and Working Laser Mode
Bug Fixes
Fixed a bug that Touchscreen could not adjusted temperature and load filament when filament ran out during print
Fixed a bug that guide procedure did not finished correctly when using 10W Laser Module and Rotary Module
Fixed a bug that Touchscreen could not adjusted B Axis origin when using 20W/40W Laser Module and Rotary Module
Fixed a bug that Touchscreen showed wrong elapsed time in some scenario
Improvements
Improved Touchscreen UI/UX with Dual Extrusion 3D Printing Module and Quick Swap Kit
Optimized Toucreen processing for file transfer and upgrade when local storage is low
Notice: When local storage is low or insufficient, Touchscreen will clean up local files for free up enough space (according to the file created time locally, from earliest to latest).
Mainboard
New Features
M3/M4 Gcode update
Support for M3/M4 to turn Trapizoid Power on or off (in Marlin definition). This differs from standard Marlin, which configures LASER_POWER_TRAP when compiling firmware. The M3/M4 definition will now favor grbl.
Marlin’s M3 I and M4 I switching between Continuous Inline Mode and Dynamic Inline Mode is currently not supported. It is important to note that Marlin’s definition of Dynamic Inline Mode is not the same as Grbl’s definition of Dynamic Laser Power Mode.
G0/G1 Gcode update
In both M3 and M4, the laser is turned off when using the G0 movement.
Both Marlin and GRBL types of Inline Mode.
Module
Bug Fixes
Fixed a bug that flame sensor triggered on boot up unexpectedly in 20W/40W Laser Module
Changelog
Mainboard
Bug Fixes
Fixed a bug that Laser power was turned off in printing in some scenario.
Changelog
Touchscreen
Bug Fixes
Fixed a bug that Touchscreen did not show dialog when 20W/40W Laser Module sensor triggered
Fixed a bug that when Snapmaker Luban could not change nozzle and heated bed temperature when connected via Wi-Fi
Mainboard
Bug Fixes
Fixed 20W/40W Laser Module exception behavior when started a new print job.
In this version, the machine will not start a new print job when status is abnormal
Fixed a bug that X/Y will shift when starting a print job with 20W/40W Laser in some scenario
When starting a new print job using crosshair mode in touchscreen, X/Y will shift when executing G-code which was using relative mode
Improvements
Optimized 3DP Module park position when print job paused
In this version, the 3dp module will park at the opposite x position
Improved 20W/40W Laser Module sensor behavior
When flame sensor is triggered, the machine will turn off tool head fans for safety
Fixed power loss recovery will fail when flame sensor is triggered
Changelog
Touchscreen
New Features
Added 200W CNC Module and Bracing Kit support
Added laser shot output power settings(in limited range)
You can change the settings via Settings > 20W/40W Laser Advance Settings > Laser Shot Output Power
Bug Fixes
Fixed a bug that Touchscreen could not check or download new version updates in some scenario
Fixed a bug that when using 20W/40W Laser and Rotary Module, Touchscreen did not show safety notice before print started
Improvements
Added received file shortcut in remote connection
File shortcut option will be available when the machine is not printing. The file will be the last received file with current connection
Added disable option for 20W/40W Laser Fire Sensor Sensitivity
Disable fire sensor sensitivity option will erase the sensitivity value
Optimized UI/UX when choosing update files, there will be confirm dialog when choosing update file
Changelog
Touchscreen
New Features
Added 2W Infrared Laser Module Supported
Bug Fixes
Fixed a bug that when machine print job completed, transfer G-code file via Snapmaker Luban and start print job immediately will cause start print job failed.
Fixed a bug that Touchscreen shows wrong spindle speed params in Preview page when using 200W CNC Module
Preview will display 18000 rpm as default for 200 CNC Module now(12000 rpm previously)
Mainboard
New Features
Bug Fixes
Fixed a bug that print job shifted when using 20W/40W Laser Module crosshair mode to set work origin in some scenario
E.g. Including both Relative Mode and Absolute Mode in Print G-code file
Improvements
Optimized work speed modification in print, preventing machine print failed from set work speed to 0%
Changelog
Touchscreen
Bug Fixes
Fixed a bug that the Air Purifier “Auto Turn On” option was not activated during machining of 20W/40W Laser Module or 2W Infrared Laser Module
Module
Bug Fixes
Fixed a bug that 2W Infrared Laser Module would automatically emit upon initialization
Improvements
When 2W Infrared Laser Module is in stand-by, the inner fan running at low speed will be turned off to reduce noise
Added Direct Machine Connection support for Snapmaker Orca. You can now send G-code to your machine over Wi-Fi without using Luban as a transfer station. Snapmaker Orca communicates directly with your machine through the OctoPrint protocol.
Added a Repeat Job button on the touchscreen. After a 3D printing, laser, or CNC job finishes, you’ll see an option to repeat the job and start it again with one tap.
With the beta firmware you no longer need to open Snapmaker Luban first to establish the connection. The only difference from before is the IP-address format, which now becomes: current device IP:8080 , e.g., 192.168.0.1:8080 .
When using the single-head dual-nozzle setup for bed-level preheat or XY-offset calibration, uploading & starting a print from Orca will interrupt the calibration.
Uploading & starting a print from both Snapmaker Luban and Snapmaker Orca at the same time will cause the job to fail.
In some cases, sending a file via Snapmaker Orca may stick at 0 % upload progress; if this happens, restart the machine and provide logs plus a description of the problem.
When using the rotary module, the “re-print” function may occasionally restart the job at a different origin.
When re-printing with the laser module, pausing during the downward move will cause the return-to-origin to fail.
