May 19 2023: Snapmaker2_V1.15.26
Thank you for your suggestions on how to make the Snapmaker 2.0 better. Your feedback is always appreciated. Here comes the latest version of the Snapmaker 2.0 firmware.
Changelog
Touchscreen
New Features
- Added retraction warning if G-code retraction distance was not recommended in Dual Extrusion 3D Printing Module
Bug Fixes
- Fixed a bug that adjusting the Initial Layer nozzle temperature and heated bed temperature failed in 3D Printing
Controller
New Features
- Added “C” and “W” custom parameter support with “M109” G-code
Improvement
- Reduced retraction distance when pausing in 3D Printing job
Downloads
MD5: 546a8100bd5b9a3cd1b7cef9734e0484
Notes
- This firmware update is only compatible with Snapmaker 2.0.
- To see your current firmware version, go to Settings > About Machine .
How to Update Firmware
- Via a USB flash drive
- Put the firmware update file Snapmaker2_V{version}.bin in your USB flash drive.
- Plug the drive into the Controller.
- On the Touchscreen, tap Files > USB > Snapmaker2_V{version}.bin.
- Via Wi-Fi
- On the Touchscreen, tap Settings > Firmware Update.
- Read the changelog and download the firmware.
- After the firmware is downloaded, tap Update Now.
