We are working on it. We recently just added Japanese to the touchscreen
I can confirm this issue still exists in the latest firmware 1.10.1
I didnât notice at first what the issue was for my heat profile tower, but the screen shows the current and target temp always as the highest in the file which also happens to be the last temp it is set to so it is hard to say which it is choosing.
@staff please assist/ resolve
See attached for 2 gcode files. Scratch that. one was too big.
tour_de_chauffe_v2.gcode (756.1 KB)
I can also confirm this issue still exists in latest firmware
Sadly I cant upload the gcode being newâŚ
Can you please please fix this @staff
Hi all. I have observed the same issue - latest versions of Luban (3.12.3) AND fimware (1.10.1) are installed. I did a liâl experiment and deleted the line in the header file that sets the initial hot end temp. Hmmm, the machine didnât seem to like that and I ended up having to cycle the power because it appeared to go unresponsive.
So, I deleted the entire header. All of it. Not commented out. Deleted.
The machine is liking that much better, although you of course donât get the little picture of the job on the touchscreen, but, meh. Im building a PETG temp tower as I type, so weâre starting at a heady 265c, but it is getting to 265 no issue. When the temps start to fall (and I have manually inserted M109 so it waits) Iâm hoping it will behave. I think it should as it parsed the 161,500 lines of code without throwing any errors!
Iâll report back.
Ed.
âŚAaaaaaaanndd it followed the G-code perfectly. Makes me a happy chappie.
