First post here! I was hoping to put together a set of standard calibration prints that I use for new filaments/spools of filaments to dial in settings with minimal prints required.
I am looking to include a temp tower and test print for linear advance values but I am told that other users have had trouble with SM2.0 ignoring commands to change temp or to set K value (linear advance) such as M900 Kx.x.
Im not entirely understanding your reply. From what I can see, the link is to the SM1 gcode reference file.
What I dont understand is why it being missing from this reference file would mean that It would ignore a built in gcode command? When entering M503, I can see the linear advance value printed in the console “M900 K0.22” so it seems there is a parameter saved for this (the default Marlin value for K).
I have been able to manually change the K value using M900 and have seen it affect print quality so it seems to respond to manual changes. Just wondering if there was a way to get it to respond to the M900 commands generated in a tuning file from Marlin found here: https://marlinfw.org/tools/lin_advance/k-factor.html
I think the M900 command works. The table shows modifications we made to original Marlin G-code, and most of Marlin G-code are supported in both SM1 and SM2. We will rearrange a new document as an official G-code reference on our website later.
Is anyone else seeing where the initial bed and extruder heat to temperature codes are being used but the Snapmaker 2 is ignoring all subsequent M104 and M140 codes in the files? I went as far as setting it up so they are reset at every level change and my SM2 A350 continued to print at the initial layer values.
This occurred with both the SM Luban software and code I generated from the Prusa Slicer applications and the M codes were in both files where I expected them to be.
So far this is making it so I either have better bed adhesion with PLA but with stringing and niblets bleeding off the object or better print quality and essentially eliminating the string with a greater chance of the print not adhering well from the the first layer to the bed (although I must admit the included coated spring metal bed is easier to adhere to that most).
This is the exact issue I am talking about, the same happens for temp towers where the M104 and M140 commands are included in the gcode but the SM2 seemingly ignores these values and continues with the initial temps.
The only solution with the current firmware that I can figure out is to manually change the temperature at the correct time. A possible activity when it involves the initial layer and a change to the following layers, but with a layer tower that means staying nearby and watching for the correct time to change to the next temperature.
I can now confirm it is the touchscreen controller parsing the gcode that causes the temperature gcodes and others to be ignored. I disconnected the touchscreen and setup Octoprint on a Pi 4 B and my same start code works as expected. I can now send the gcode directly from PrusaSlicer and start a print. A few more tweaks to do before it is ready for primetime though.
I assume you are also aware but forgot to mention that there is also a bug with M900 g-code commands too? This I would like to see fixed as well as it would make calibration for new filaments much simpler
M900 works through the console for me as well but it does not seem to work when embedded in a g-code file like when tuning the linear advance “K” value
I have to state that only these 4 commands are overwritten by TS in order to have the adjustment feature. We don’t have any reason to change the behavior of original M900.
I can confirm that M104 and M109 commands are now working when embedded in g-code files. However, the M900 commands still seem to be ignored (see image below). I would expect to see different behaviour across the K value range of 0-0.2.
