SnapMaker 2 Marlin 2 gCode Support
As the title suggests, I’m hoping Jade, et. al., can provide at least the brief doc that was under development over the past year, indicating current gcode support for the SM1/SM2 series. I’d like to provide support for third-party multi-color functionality as well as some other projects under development that will expand the audience for the SM2 as its rolled out.
I know I can brute-force every command (G/M) from a terminal line; I still wont have positive confirmation for those commands with multiple optional parameters.
Any help here would be most appreciated!
Hi Trek, thank you for your suggestions and we appreciate your input and here is the g-code reference file we have ready as of now for SM1. The g-code reference file for SM2 will be released in a month or two according to the plan. Sorry if the g-code reference file we have now is a bit bare boned, but we will refine it with time. Here is the link to the g-code reference file for SM1.
Any timeline on releasing the Marlin 2.0 source for SM2 as required by the GPL v3 license?
Thanks
Any update on this, looking for a Snapmaker 2 gcode reference?
You can have a look at the source code of the firmware,
@JKC20 Any update on the snapmaker2 custom gcodes, if possible can you put them in this thread as it leads here from the custom snapmaker1 gcodes via a link to your post.
Thanks!
@tyeth
* "G" Codes
 * G0   -> G1
 * G1   - Coordinated Movement X Y Z E
 * G2   - CW ARC
 * G3   - CCW ARC
 * G4   - Dwell S<seconds> or P<milliseconds>
 * G5   - Cubic B-spline with XYZE destination and IJPQ offsets
 * G10  - Retract filament according to settings of M207 (Requires FWRETRACT)
 * G11  - Retract recover filament according to settings of M208 (Requires FWRETRACT)
 * G12  - Clean tool (Requires NOZZLE_CLEAN_FEATURE)
 * G17  - Select Plane XY (Requires CNC_WORKSPACE_PLANES)
 * G18  - Select Plane ZX (Requires CNC_WORKSPACE_PLANES)
 * G19  - Select Plane YZ (Requires CNC_WORKSPACE_PLANES)
 * G20  - Set input units to inches (Requires INCH_MODE_SUPPORT)
 * G21  - Set input units to millimeters (Requires INCH_MODE_SUPPORT)
 * G26  - Mesh Validation Pattern (Requires G26_MESH_VALIDATION)
 * G27  - Park Nozzle (Requires NOZZLE_PARK_FEATURE)
 * G28  - Home one or more axes
 * G29  - Start or continue the bed leveling probe procedure (Requires bed leveling)
 * G30  - Single Z probe, probes bed at X Y location (defaults to current XY location)
 * G31  - Dock sled (Z_PROBE_SLED only)
 * G32  - Undock sled (Z_PROBE_SLED only)
 * G33  - Delta Auto-Calibration (Requires DELTA_AUTO_CALIBRATION)
 * G34  - Z Stepper automatic alignment using probe: I<iterations> T<accuracy> A<amplification> (Requires Z_STEPPER_AUTO_ALIGN)
 * G38  - Probe in any direction using the Z_MIN_PROBE (Requires G38_PROBE_TARGET)
 * G42  - Coordinated move to a mesh point (Requires MESH_BED_LEVELING, AUTO_BED_LEVELING_BLINEAR, or AUTO_BED_LEVELING_UBL)
 * G80  - Cancel current motion mode (Requires GCODE_MOTION_MODES)
 * G90  - Use Absolute Coordinates
 * G91  - Use Relative Coordinates
 * G92  - Set current position to coordinates given
 * "M" Codes
 * M0   - Unconditional stop - Wait for user to press a button on the LCD (Only if ULTRA_LCD is enabled)
 * M1   -> M0
 * M3   - Turn laser/spindle on, set spindle/laser speed/power, set rotation to clockwise
 * M4   - Turn laser/spindle on, set spindle/laser speed/power, set rotation to counter-clockwise
 * M5   - Turn laser/spindle off
 * M12  - Set up closed loop control system. (Requires EXTERNAL_CLOSED_LOOP_CONTROLLER)
 * M17  - Enable/Power all stepper motors
 * M18  - Disable all stepper motors; same as M84
 * M20  - List SD card. (Requires SDSUPPORT)
 * M21  - Init SD card. (Requires SDSUPPORT)
 * M22  - Release SD card. (Requires SDSUPPORT)
 * M23  - Select SD file: "M23 /path/file.gco". (Requires SDSUPPORT)
 * M24  - Start/resume SD print. (Requires SDSUPPORT)
 * M25  - Pause SD print. (Requires SDSUPPORT)
 * M26  - Set SD position in bytes: "M26 S12345". (Requires SDSUPPORT)
 * M27  - Report SD print status. (Requires SDSUPPORT)
 *        OR, with 'S<seconds>' set the SD status auto-report interval. (Requires AUTO_REPORT_SD_STATUS)
 *        OR, with 'C' get the current filename.
 * M28  - Start SD write: "M28 /path/file.gco". (Requires SDSUPPORT)
 * M29  - Stop SD write. (Requires SDSUPPORT)
 * M30  - Delete file from SD: "M30 /path/file.gco"
 * M31  - Report time since last M109 or SD card start to serial.
 * M32  - Select file and start SD print: "M32 [S<bytepos>] !/path/file.gco#". (Requires SDSUPPORT)
 *        Use P to run other files as sub-programs: "M32 P !filename#"
 *        The '#' is necessary when calling from within sd files, as it stops buffer prereading
 * M33  - Get the longname version of a path. (Requires LONG_FILENAME_HOST_SUPPORT)
 * M34  - Set SD Card sorting options. (Requires SDCARD_SORT_ALPHA)
 * M42  - Change pin status via gcode: M42 P<pin> S<value>. LED pin assumed if P is omitted.
 * M43  - Display pin status, watch pins for changes, watch endstops & toggle LED, Z servo probe test, toggle pins
 * M48  - Measure Z Probe repeatability: M48 P<points> X<pos> Y<pos> V<level> E<engage> L<legs> S<chizoid>. (Requires Z_MIN_PROBE_REPEATABILITY_TEST)
 * M75  - Start the print job timer.
 * M76  - Pause the print job timer.
 * M77  - Stop the print job timer.
 * M78  - Show statistical information about the print jobs. (Requires PRINTCOUNTER)
 * M80  - Turn on Power Supply. (Requires POWER_SUPPLY > 0)
 * M81  - Turn off Power Supply. (Requires POWER_SUPPLY > 0)
 * M82  - Set E codes absolute (default).
 * M83  - Set E codes relative while in Absolute (G90) mode.
 * M84  - Disable steppers until next move, or use S<seconds> to specify an idle
 *        duration after which steppers should turn off. S0 disables the timeout.
 * M85  - Set inactivity shutdown timer with parameter S<seconds>. To disable set zero (default)
 * M92  - Set planner.settings.axis_steps_per_mm for one or more axes.
 * M100 - Watch Free Memory (for debugging) (Requires M100_FREE_MEMORY_WATCHER)
 * M104 - Set extruder target temp.
 * M105 - Report current temperatures.
 * M106 - Set print fan speed.
 * M107 - Print fan off.
 * M108 - Break out of heating loops (M109, M190, M303). With no controller, breaks out of M0/M1. (Requires EMERGENCY_PARSER)
 * M109 - Sxxx Wait for extruder current temp to reach target temp. Waits only when heating
 *        Rxxx Wait for extruder current temp to reach target temp. Waits when heating and cooling
 *        If AUTOTEMP is enabled, S<mintemp> B<maxtemp> F<factor>. Exit autotemp by any M109 without F
 * M110 - Set the current line number. (Used by host printing)
 * M111 - Set debug flags: "M111 S<flagbits>". See flag bits defined in enum.h.
 * M112 - Emergency stop.
 * M113 - Get or set the timeout interval for Host Keepalive "busy" messages. (Requires HOST_KEEPALIVE_FEATURE)
 * M114 - Report current position.
 * M115 - Report capabilities. (Extended capabilities requires EXTENDED_CAPABILITIES_REPORT)
 * M117 - Display a message on the controller screen. (Requires an LCD)
 * M118 - Display a message in the host console.
 * M119 - Report endstops status.
 * M120 - Enable endstops detection.
 * M121 - Disable endstops detection.
 * M122 - Debug stepper (Requires at least one _DRIVER_TYPE defined as TMC2130/TMC2208/TMC2660)
 * M125 - Save current position and move to filament change position. (Requires PARK_HEAD_ON_PAUSE)
 * M126 - Solenoid Air Valve Open. (Requires BARICUDA)
 * M127 - Solenoid Air Valve Closed. (Requires BARICUDA)
 * M128 - EtoP Open. (Requires BARICUDA)
 * M129 - EtoP Closed. (Requires BARICUDA)
 * M140 - Set bed target temp. S<temp>
 * M145 - Set heatup values for materials on the LCD. H<hotend> B<bed> F<fan speed> for S<material> (0=PLA, 1=ABS)
 * M149 - Set temperature units. (Requires TEMPERATURE_UNITS_SUPPORT)
 * M150 - Set Status LED Color as R<red> U<green> B<blue> P<bright>. Values 0-255. (Requires BLINKM, RGB_LED, RGBW_LED, NEOPIXEL_LED, PCA9533, or PCA9632).
 * M155 - Auto-report temperatures with interval of S<seconds>. (Requires AUTO_REPORT_TEMPERATURES)
 * M163 - Set a single proportion for a mixing extruder. (Requires MIXING_EXTRUDER)
 * M164 - Commit the mix and save to a virtual tool (current, or as specified by 'S'). (Requires MIXING_EXTRUDER)
 * M165 - Set the mix for the mixing extruder (and current virtual tool) with parameters ABCDHI. (Requires MIXING_EXTRUDER and DIRECT_MIXING_IN_G1)
 * M166 - Set the Gradient Mix for the mixing extruder. (Requires GRADIENT_MIX)
 * M190 - Sxxx Wait for bed current temp to reach target temp. ** Waits only when heating! **
 *        Rxxx Wait for bed current temp to reach target temp. ** Waits for heating or cooling. **
 * M200 - Set filament diameter, D<diameter>, setting E axis units to cubic. (Use S0 to revert to linear units.)
 * M201 - Set max acceleration in units/s^2 for print moves: "M201 X<accel> Y<accel> Z<accel> E<accel>"
 * M202 - Set max acceleration in units/s^2 for travel moves: "M202 X<accel> Y<accel> Z<accel> E<accel>" ** UNUSED IN MARLIN! **
 * M203 - Set maximum feedrate: "M203 X<fr> Y<fr> Z<fr> E<fr>" in units/sec.
 * M204 - Set default acceleration in units/sec^2: P<printing> R<extruder_only> T<travel>
 * M205 - Set advanced settings. Current units apply:
            S<print> T<travel> minimum speeds
            B<minimum segment time>
            X<max X jerk>, Y<max Y jerk>, Z<max Z jerk>, E<max E jerk>
 * M206 - Set additional homing offset. (Disabled by NO_WORKSPACE_OFFSETS or DELTA)
 * M207 - Set Retract Length: S<length>, Feedrate: F<units/min>, and Z lift: Z<distance>. (Requires FWRETRACT)
 * M208 - Set Recover (unretract) Additional (!) Length: S<length> and Feedrate: F<units/min>. (Requires FWRETRACT)
 * M209 - Turn Automatic Retract Detection on/off: S<0|1> (For slicers that don't support G10/11). (Requires FWRETRACT_AUTORETRACT)
          Every normal extrude-only move will be classified as retract depending on the direction.
 * M211 - Enable, Disable, and/or Report software endstops: S<0|1> (Requires MIN_SOFTWARE_ENDSTOPS or MAX_SOFTWARE_ENDSTOPS)
 * M217 - Set filament swap parameters: "M217 S<length> P<feedrate> R<feedrate>". (Requires SINGLENOZZLE)
 * M218 - Set/get a tool offset: "M218 T<index> X<offset> Y<offset>". (Requires 2 or more extruders)
 * M220 - Set Feedrate Percentage: "M220 S<percent>" (i.e., "FR" on the LCD)
 * M221 - Set Flow Percentage: "M221 S<percent>"
 * M226 - Wait until a pin is in a given state: "M226 P<pin> S<state>"
 * M240 - Trigger a camera to take a photograph. (Requires PHOTO_GCODE)
 * M250 - Set LCD contrast: "M250 C<contrast>" (0-63). (Requires LCD support)
 * M260 - i2c Send Data (Requires EXPERIMENTAL_I2CBUS)
 * M261 - i2c Request Data (Requires EXPERIMENTAL_I2CBUS)
 * M280 - Set servo position absolute: "M280 P<index> S<angle|µs>". (Requires servos)
 * M281 - Set servo min|max position: "M281 P<index> L<min> U<max>". (Requires EDITABLE_SERVO_ANGLES)
 * M290 - Babystepping (Requires BABYSTEPPING)
 * M300 - Play beep sound S<frequency Hz> P<duration ms>
 * M301 - Set PID parameters P I and D. (Requires PIDTEMP)
 * M302 - Allow cold extrudes, or set the minimum extrude S<temperature>. (Requires PREVENT_COLD_EXTRUSION)
 * M303 - PID relay autotune S<temperature> sets the target temperature. Default 150C. (Requires PIDTEMP)
 * M304 - Set bed PID parameters P I and D. (Requires PIDTEMPBED)
 * M350 - Set microstepping mode. (Requires digital microstepping pins.)
 * M351 - Toggle MS1 MS2 pins directly. (Requires digital microstepping pins.)
 * M355 - Set Case Light on/off and set brightness. (Requires CASE_LIGHT_PIN)
 * M380 - Activate solenoid on active extruder. (Requires EXT_SOLENOID)
 * M381 - Disable all solenoids. (Requires EXT_SOLENOID)
 * M400 - Finish all moves.
 * M401 - Deploy and activate Z probe. (Requires a probe)
 * M402 - Deactivate and stow Z probe. (Requires a probe)
 * M403 - Set filament type for PRUSA MMU2
 * M404 - Display or set the Nominal Filament Width: "W<diameter>". (Requires FILAMENT_WIDTH_SENSOR)
 * M405 - Enable Filament Sensor flow control. "M405 D<delay_cm>". (Requires FILAMENT_WIDTH_SENSOR)
 * M406 - Disable Filament Sensor flow control. (Requires FILAMENT_WIDTH_SENSOR)
 * M407 - Display measured filament diameter in millimeters. (Requires FILAMENT_WIDTH_SENSOR)
 * M410 - Quickstop. Abort all planned moves.
 * M412 - Enable / Disable Filament Runout Detection. (Requires FILAMENT_RUNOUT_SENSOR)
 * M413 - Enable / Disable Power-Loss Recovery. (Requires POWER_LOSS_RECOVERY)
 * M420 - Enable/Disable Leveling (with current values) S1=enable S0=disable (Requires MESH_BED_LEVELING or ABL)
 * M421 - Set a single Z coordinate in the Mesh Leveling grid. X<units> Y<units> Z<units> (Requires MESH_BED_LEVELING, AUTO_BED_LEVELING_BILINEAR, or AUTO_BED_LEVELING_UBL)
 * M422 - Set Z Stepper automatic alignment position using probe. X<units> Y<units> A<axis> (Requires Z_STEPPER_AUTO_ALIGN)
 * M425 - Enable/Disable and tune backlash correction. (Requires BACKLASH_COMPENSATION and BACKLASH_GCODE)
 * M428 - Set the home_offset based on the current_position. Nearest edge applies. (Disabled by NO_WORKSPACE_OFFSETS or DELTA)
 * M500 - Store parameters in EEPROM. (Requires EEPROM_SETTINGS)
 * M501 - Restore parameters from EEPROM. (Requires EEPROM_SETTINGS)
 * M502 - Revert to the default "factory settings". ** Does not write them to EEPROM! **
 * M503 - Print the current settings (in memory): "M503 S<verbose>". S0 specifies compact output.
 * M524 - Abort the current SD print job (started with M24)
 * M540 - Enable/disable SD card abort on endstop hit: "M540 S<state>". (Requires ABORT_ON_ENDSTOP_HIT_FEATURE_ENABLED)
 * M569 - Enable stealthChop on an axis. (Requires at least one #_X_DRIVER_TYPE to be TMC2130 or TMC2208)
 * M600 - Pause for filament change: "M600 X<pos> Y<pos> Z<raise> E<first_retract> L<later_retract>". (Requires ADVANCED_PAUSE_FEATURE)
 * M603 - Configure filament change: "M603 T<tool> U<unload_length> L<load_length>". (Requires ADVANCED_PAUSE_FEATURE)
 * M605 - Set Dual X-Carriage movement mode: "M605 S<mode> [X<x_offset>] [R<temp_offset>]". (Requires DUAL_X_CARRIAGE)
 * M665 - Set delta configurations: "M665 H<delta height> L<diagonal rod> R<delta radius> S<segments/s> B<calibration radius> X<Alpha angle trim> Y<Beta angle trim> Z<Gamma angle trim> (Requires DELTA)
 * M666 - Set/get offsets for delta (Requires DELTA) or dual endstops (Requires [XYZ]_DUAL_ENDSTOPS).
 * M701 - Load filament (Requires FILAMENT_LOAD_UNLOAD_GCODES)
 * M702 - Unload filament (Requires FILAMENT_LOAD_UNLOAD_GCODES)
 * M810-M819 - Define/execute a G-code macro (Requires GCODE_MACROS)
 * M851 - Set Z probe's Z offset in current units. (Negative = below the nozzle.)
 * M852 - Set skew factors: "M852 [I<xy>] [J<xz>] [K<yz>]". (Requires SKEW_CORRECTION_GCODE, and SKEW_CORRECTION_FOR_Z for IJ)
 * M860 - Report the position of position encoder modules.
 * M861 - Report the status of position encoder modules.
 * M862 - Perform an axis continuity test for position encoder modules.
 * M863 - Perform steps-per-mm calibration for position encoder modules.
 * M864 - Change position encoder module I2C address.
 * M865 - Check position encoder module firmware version.
 * M866 - Report or reset position encoder module error count.
 * M867 - Enable/disable or toggle error correction for position encoder modules.
 * M868 - Report or set position encoder module error correction threshold.
 * M869 - Report position encoder module error.
 * M900 - Get or Set Linear Advance K-factor. (Requires LIN_ADVANCE)
 * M906 - Set or get motor current in milliamps using axis codes X, Y, Z, E. Report values if no axis codes given. (Requires at least one _DRIVER_TYPE defined as TMC2130/TMC2208/TMC2660)
 * M907 - Set digital trimpot motor current using axis codes. (Requires a board with digital trimpots)
 * M908 - Control digital trimpot directly. (Requires DAC_STEPPER_CURRENT or DIGIPOTSS_PIN)
 * M909 - Print digipot/DAC current value. (Requires DAC_STEPPER_CURRENT)
 * M910 - Commit digipot/DAC value to external EEPROM via I2C. (Requires DAC_STEPPER_CURRENT)
 * M911 - Report stepper driver overtemperature pre-warn condition. (Requires at least one _DRIVER_TYPE defined as TMC2130/TMC2208/TMC2660)
 * M912 - Clear stepper driver overtemperature pre-warn condition flag. (Requires at least one _DRIVER_TYPE defined as TMC2130/TMC2208/TMC2660)
 * M913 - Set HYBRID_THRESHOLD speed. (Requires HYBRID_THRESHOLD)
 * M914 - Set StallGuard sensitivity. (Requires SENSORLESS_HOMING or SENSORLESS_PROBING)
 * M917 - L6470 tuning: Find minimum current thresholds
 * M918 - L6470 tuning: Increase speed until max or error
 * M951 - Set Magnetic Parking Extruder parameters. (Requires MAGNETIC_PARKING_EXTRUDER)
 * M360 - SCARA calibration: Move to cal-position ThetaA (0 deg calibration)
 * M361 - SCARA calibration: Move to cal-position ThetaB (90 deg calibration - steps per degree)
 * M362 - SCARA calibration: Move to cal-position PsiA (0 deg calibration)
 * M363 - SCARA calibration: Move to cal-position PsiB (90 deg calibration - steps per degree)
 * M364 - SCARA calibration: Move to cal-position PSIC (90 deg to Theta calibration position)
 * ************ Custom codes - This can change to suit future G-code regulations
 * M928 - Start SD logging: "M928 filename.gco". Stop with M29. (Requires SDSUPPORT)
 * M997 - Perform in-application firmware update
 * M999 - Restart after being stopped by error
 * "T" Codes
 * T0-T3 - Select an extruder (tool) by index: "T<n> F<units/min>"
except don’t use G29 and use the undocumented G1029 instead, lol - i just bugged the fact that G29 S0 does nasty things… i also bugged how incomplete the snapmaker
gcode docs are :frowning:
snapmaker should update this or remove it IMHO https://snapmaker.github.io/Documentation/gcode/G000-G001
@scyto I just took it from the GitHub, because for some reason the official thread here on the forum somehow no longer exists.
yeah good call, wasn’t criticizing, just moaning as usual about snapmaker :slight_smile:
@scyto I did my share of moaning about Snapmaker for the day earlier LOL
Update to [quote=“Artezio, post:7, topic:5155”]
Just went thru the code and added what I found, namely:
M1000
M1005
M1007
M1010
M1011
M1028
M1029
 * G-Codes in Marlin
 * Helpful G-code references:
 *  - http://linuxcnc.org/handbook/gcode/g-code.html
 *  - http://objects.reprap.org/wiki/Mendel_User_Manual:_RepRapGCodes
 * Help to document Marlin's G-codes online:
 *  - http://reprap.org/wiki/G-code
 *  - https://github.com/MarlinFirmware/MarlinDocumentation
 * "G" Codes
 * G0   -> G1
 * G2   - CW ARC
 * G3   - CCW ARC
 * "M" Codes
 * M1   -> M0
 * M1000: Resume from power-loss (undocumented)
   * With 'S' go to the Resume/Cancel menu
   * With no parameters, run recovery commands
 * M1005 - Firmware version
 * M1007 - Query active_coordinate_system
 * M1010 - Control/query chamber status, compatible with Snapmaker1
 * M1011 - Control/query purifier status
 * M1028 Configure the customize parameters of snapmaker
	* S:
	* 0: show current parameters
	* 1: home feedrate, X<X speed> Y<Y speed> Z<Z speed>
	* 2: home bump speed divisor
	* 3: max feedrate in calibration, X<X speed> Y<Y speed> Z<Z speed>
	* 4: feedrate in calibration, X<X speed> Y<Y speed> Z<Z speed>
	* 5: Z postions in calibration, details please see comments above
	* 6: laser power in calibration
	* 7: z limit in calibration
	* 8: speed in drawing ruler
 * M1029 - Remap the 8 pin port to any axis 8 pin number: 1 - 6 eg. M1029 X2 Y3 Z4 B5 E6
 * "T" Codes
[/quote]
