SM Ray max cut area relative to frame
Hi all
I’m just putting together an enclosure design and need to locate the cutting bed relative to the max rectangle achievable with 20w module fitted.
A laptop I set aside to run the laser has developed a hardrive issue and needs repair or replacement, so I cant mark out the area that way.
I powered up the machine and used the red crosshair but cant find the offset measurement to the laser dot.
I’m wondering if anyone has made this measurement previously and can tell me how the work area cutting bed (outside edge) is positioned in mm from the inside face of the Left hand Y axis and inward from the front of the Y axis rails (asuming a level is placed across both Y axis front ends).
I intend the frame to sit flat on a sheet of plywood that runs over the top of the cutting bed with the actual work area cut out so a jig to hold work pieces can be placed within that rectangle.
I’m also cutting a feedthrough into the front & back pannel of the enclosure.
