I purchased a 40w Ray with enclosure recently and love it. The only issue I’ve noticed is that there is no floor to the enclosure, which means the rails for the Ray and the bed are just sitting loosely inside the enclosure. Aligning the bed is simple enough, but since both systems are just loose, it is very easy for one or both to get bumped when loading/unloading large pieces of material, causing them to lose alignment right before you begin an engraving. For precision work, this can be problematic.
I planned on making a base for the enclosure that would have cutouts for the feet of the Ray rails and the work table to ensure alignment and proper positioning, but figured I’d reach out here before reinventing the wheel in case someone else had already come up with a solution. If anyone knows of a solution that already exists, it would be greatly appreciated. If not, when I design and make mine, I’m happy to report back with it for anyone that would like it.
Thanks!
