I’m not sure if this is a bug with either the firmware or the Luban software. Sometimes it’s super difficult to connect to my A250 via Wifi. Regardless of what I do, the machine’s IP just doesn’t show up in the connection section. How I connect to the machine seems completely random and depends on luck. It’s very annoying when it takes ~30 mins just to get connected to your machine.
The Luban software I’m using is the latest version. But I haven’t updated the firmware at all so it’s probably still the factory default version.
Anyone has similar problem? Should I upgrade the firmware?
I recently changed the home WiFi password,
but when I went to update it on my SM, it own’t save the new password or connect
I’ve tried inputting it a number of times and rebooting it
but it still won’t connect vie WiFi?
Any ideas?
My A250 touch screen is running V1.9.0 and my controller is V3.1.2
Hello, I have a problem with my SM A250; cannot connect to either PC or Mac. I tested with Luban 3.7, 3.8, 3.9, Firmware 1.9, 1.10, 1.10.1, Port com4, com5, com6, com9, supplied cable and other cable (the PC is dingdong, so a connection exists).
Restarted the whole mess, cables connected or not = kifkif.
The best answer I got was “the machine is not ready”.
In WiFi, simply NOTHING, even if you enter the IP address manually.
It’s not my computers, because when I plug something else into USB or WiFi, it works perfectly.
Any ideas?
Yes it worked, I didn’t modify anything on my computers. These days I loaded my G-Codes via a USB key because the Mac on which I model my parts is on another floor and it’s boring to walk twice to confirm on the touchscreen … wanted to calibrate the extruder, so I thought I would do it from my laptop … and connection
