Seeking Good Table/Workbench for A350 with Enclosure
I’ve been looking for a table, desk, or workbench that is deep enough to accommodate the A350 with the enclosure. All of the workbenches I’ve found are only 20" deep. Anyone have any suggestions for a sturdy foundation for the A350+Enclosure that is big enough to accommodate it, the power supply, the filter, etc?
I was lazy and just plopped mine on a 36" folding table. :neutral_face: I don’t have the air purifier, I run the hose to a window and printed some things to fit better so it holds. Power supply I printed out some straps that attach it to the back of the enclosure. With the weight of the snapmaker and enclosure, it makes the table fairly rigid and even on fast back and forth fills with the laser, it doesn’t rock or move.
Good suggestion! Thanks!
I used the Ikea Bror trolley.
Wide enough to fit the A350 enclosure base, although I am tempted to install a wider top section.
I have a height adjustable desk from Staples and i love it. i can raise it eye level or lower it to only couple feet from the floor. i do not have purifier but i expect it too would fit. i have the A350 with enclosure.
Depending on budget, these tables are pricey. Company paid for it for me.
AllSteel Altitude A6 48x30
https://www.allsteeloffice.com/products/tables/height-adjustable/altitude-a6
I use the following Gry Mattr Parsons Desk - White | staples.ca. Large desk that is extra strong with extra surface to work on projects.
I use two height adjustable legs: ADB Werkbankfuß, höhenverstellbar, Lichtgrau (RAL 7035) | ADB - they are nice, because you can level the surface
Along with a generic multiplex board of 1250 x 700 mm (this is basically the surface of the enclosure plus around 20cm of extra space): https://www.amazon.de/dp/B00GRZ9N00/ref=pe_27091401_487027711_TE_SCE_3p_dp_1?language=en_GB
