Scotch Blue Tape this is a hint
#1
Hello
I use scotch blue painters tape https://www.amazon.com/ScotchBlue-Pre-taped-Painters-Plastic-24-Inches/dp/B00D8OFE9C/ref=sr_1_4?ie=UTF8&qid=1548446127&sr=8-4&keywords=scotch+blue+painters+tape
You don’t need the scraper anymore, I read this clue and it’s a great thing to print.
It works perfect with PLA with ABS I don’t know yet.
#2
quick question on this. Does the heatbed need to be turned off? Or it doesn’t matter?
#3
You can use a heated bed if you want. I always have with blue tape… TBH though I’ve found the bed stickers are almost always better. I found this guide that does a good job of explaining the best practices of using blue tape if you are wanting to try that over the stickers.
