We had a power failure and our wifi router rebooted
Since then I can physically connect with a cable but not Wifi. Also the machine has stopped multiple times in the middle of a run.
Unsure of what do to
Corry
Corry
To avoid lots of suggestions on what to check that you have done already: What steps have you taken on the Ray to reconnect?
Hi
I have rebooted the laptop and Ray. I have connected with the Serial Cable and can connect and upload.
Will check Firmware tonight
So you haven’t gone into the settings on the machine and checked the wifi connection?
Maybe this will help:
https://wiki.snapmaker.com/Snapmaker_Luban/manual/connect_with_ray_via_wi-fi
