Looking for some help from interested Rotary Module users. Trying to carve a simple chain link using the ‘Linkage’ Slicing Mode but cutter won’t carve past the centreline of the material.
This is what the program produces:
Any suggestions would be appreciated.
Have you tried running the job? The preview in Luban needs some work but if you examine the toolpath it will probably look OK.
Thanks for your reply. I will design something similar but much smaller to try. The model shown was going to take 162hrs as so much waste to remove.
