Hi all i have a A350 andwould like to know if if i can buy a rotary attachment for drink bottles and if not are there any DIY plans so i can make on
thanks Wayne
| General | Rotary Module for A250 | Rotary Module for A350 |
| Weight | 2.2 kg | 2.4 kg |
| Dimensions | 120 width × 284 depth × 108 height (mm) | 120 width × 384 depth × 108 height (mm) |
| Material Length Range | 10 - 70 mm | 10 - 170 mm |
| Maximum Material Size | 70 length × 68 radius (mm) | 170 length × 68 radius (mm) |
| Inward-clamping Radius | 1 - 30 mm | |
| Outward-clamping Radius | 10 - 50 mm | |
| Frame Material | Aluminum alloy | |
| Rated Power | 7.2 W | |
| Supported Software | Snapmaker Luban, Autodesk Fusion 360, Vectric Aspire | |
| Supported File Types | .svg, .png, .jpg, .jpeg, .bmp, .dxf, .stl | |
| Supported Materials for CNC | Wood, tooling and modeling board, plastic, bamboo, wax, more being tested | |
| Supported Materials for Laser | Wood, leather, plastic, fabric, paper, non-transparent acrylic, more being tested | |
| Angle Precision | 0.1 ° | |
| Maximum Angular Speed | 45 °/s | |
| Rotation Type | 360 ° continuous | |
| Rotational Speed Conversion | 100:1 |
