Rotary 2.0 Module
Opino exactamente lo mismo creo que es una burrada ese precio, para un simple motor, asi como quieren que la comunidad gestione nuevas ideas, en fin mirare de acoplar alguno de una maquina laser que estan por 45 a 80 euros.
I have the A250 and the usable volume of the rotary module is simply too small. 70 mm? Seriously? I’m sure it is much more usable for A350 owners.
I ordered.
1st project: wooden chess figures (stl already done) .
You may want to address this ahead of time. You certainly don’t want to start with an .stl if you can avoid it. You will want a solid body. You are machining. 4th Axis simultaneous machining to be specific. It will take something akin to Fusion 360 (with full license) to do this successfully. .stl’s are for printing. Converting high quality, high detail .stl’s to solid bodies takes a lot of computer processing and creates enormous files that can cause issues.
I plan to build a Fantasy Battle Chess set with the 4th axis when I can order one. I have no files as of yet, but don’t plan to start with 3d prints and work backward.
