After installing the Quick swap kit as per instructions, during calibration the unit drives the printhead into the bed and warps it by about 15mm (the loss in build height you get from installing the kit?), leading to a “Something went wrong” popup error on the Calibrate the Bed screen. The unit has the latest firmware, and the controller is recognising the quick swap kit. The Toolhead Bracket is installed correctly, and the Snapmaker 2 Quick swap kit option is selected in Luban’s machine settings.
Check it all again.
Correct mounting holes of the quickswap and tool head?
Touchscreen settings, option quickswap enabled?
Quick stop can only be installed one way, and the toolhead is installed in the rows one down from the top row and one up from the bottom row. The touchscreen recognises the Quick Stop Kit on the homepage. I’ll try downgrading to 1.16.5.
loose x axis plug! Bed levelling fine now. Didn’t down grade but did a reset.
