2.0 250 Can't save presence of instaled quick swap kit
I have a 2.0 250 and recently installed the Quick Swap kit and can not get the machine to save that it’s there.
No issues with the physical install. Updated the machine settings in Luban to show the quick swap kit. Went into the settings on the touchscreen on the machine. Followed the prompts and told it I had the toolhead attached with quick swap instead of screws (Screws was previously selected of course). Select next and it asks about the bracing kit. Currently has “without” selected (Because I don’t have it) The “Lets Create!” button is not selectable. I can switch to installed with Bracing Kit, but still can’t proceed past this screen.
My only option is a back arrow in the upper left corner. Choosing this does not save the quick swap setting.
Tried going through these steps with the 3D print head, laser and no tool head with no changes. Tried of course turning it off and powering back up, tried resetting all settings in through experimental → Preference - > Reset All
I see a bunch of forum posts from not long after the kit launched saying its just a visual bug and from the home screen you can see the Quick Swap is showing as active, but mine does not, and when running calibration it’s very obvious it’s off by the thickness of the kit on the toolhead
Firmware version 1.20.3_20240716
Any ideas?
Solved.
I reinstalled the exact same firmeware file via USB and now it works as expected.
