Finally got some quick swap kits for my machines. Then immediately had to design some fixes… sigh.
While the QS plate lines up perfectly with the existing holes on the units that require a plate to be attached (1.6W, Single Extruder, CNC, and 10W from my modules). Thus no adjustment was needed to focus height on the laser.
Above is a QS plate attached to the 10W laser, you can see the mounting bolts directly behind it.
The 40W and 2W IR, however, that have built in QS connections… sit much lower. The IR is particularly egregious. The loss of laser height is 25.5mm for the 40W and 40.3mm for the IR. This also moves the center of gravity much lower, which causes a higher torque force on the mount point during movement, especially rapid movement. Think of a hanging weight/swing. If you move, the lower the center of gravity, the higher the lag and stress via lever force.
So I’ve modeled up some fillers to bring the mount height back to exactly where the screw mount holes are. This keeps the focus height the same (for those who use automagic header gcode), all I have to do is adjust for the thickness of the plate (11mm for built-in like the IR, and 15mm for add-on plate, like the 10W). I also had to move over 0.3mm to re-center X, but that’s almost negligible.
I also was wondering: Why do these lasers hang so deep? I usually just eyeball them to sit half way down - the force of the lever is enough to hold them in place. Requires focus calibration of course, but with the focus lever this is nice and quickly done.
Your insert introduces repeatability - so perhaps less focussing? Still, I’ll be too lazy to go down this route
I’m all about repeatability. Once everything is set up, zero fiddling. Even if I swap things out, I want it to automatically set itself up. Hard limits, mathmatical origins, etc. to ensure the highest level of accuracy is what I strive for.
FYI, the reason these lasers are designed this way is to accommodate different material thicknesses when used with Snapmaker Ray machines, which have no Z axis rails.
I figured it was a compatibility thing for other machines. Still would have been nice for snapmaker to have an official thing for the previous machines.
One thing that does strike me as odd is the lack of z movement on the Ray. They could have easily added a smaller stepper into the mount assembly for Z travel instead of dual gantry. Similar to my tiny 3018, which has 42mm of Z travel. However, I know they likely just took inspiration from other open air machines like the XTool D1 and jus to adopted their modules for it. It’s the little things that would really separate out snapmaker from the rest if they included stuff like that.
A fast rail runner with (albeit slightly limited) autofocus? Or the ability to run slight curves (such as a flask) would be a good selling point.
EDIT: Especially for cutting, automatic Z movement for multiple passes would be great. My 2.0 with 40W with 5-8mm of travel can cut 18mm plywood. Just rambling though.
