Quick swap and 40 watt?
Does the quick swap kit work with the 40 watt laser on the 2.0 350t?
Yes it does.
The Snapmaker 2.0 Quick Swap Kit is a new system that allows you to switch between functions quickly.
Overall features:
  • • One minute swap
  • • Compatible with all the toolheads that are compatible with Snapmaker 2.0
Excellent…what is the correct length screws to mount the quick swap bracket to the 40W laser toolhead? The book calls for M4 x 6 but those are too short.
I’m thinking the M4 x 8 screws are the correct screws to attached the 40W laser head to the quick swap plate.
The laser is already setup to work with the quick swap without having to add the toolhead adapter.
