Problems with Laser engraving after update
Hello Community,
I have a Problem with my Laser engraving Set Up since the latest Update. It seems Like the laser does Not Turn completly Off while moving, although i deactivated the continous Power Option of the laser. If i laser “on the path” instead of “filling” i dont have any problems. Can Somebody Help me with this issue?
Best regards
SnapiDaCroc
Which laser module is that? There are “kindof” known problems with the 10W and the 2W. Since the 2W is not good at wood, I assume this is not what you use here, right?
Did you updated Firmware and luban?
Its the 1600mW laser Module.
I updated the Luban Software.
I used it quite successful so far for engraving. For cutting it hast not enough Power..
Then please update also the firmware. There were problems with different Firmware and luban versions and lasering while travel.
hank you very much for the Tip. Engraving works again perfectly. :smiley:
You can cut with the 1600W. But you must do it in more passes. I don’t know it is possible in Luban. But in LightBurn I can do that in many passes I need and lower the head x mm every pass. I have burn a hole into oak with the 10W on 20% (2W). The communication between PC and SM was stopped and the head don’t move but the laser was on. A problem that isn’t catch by the SM firmware. No communication? Stop the action.
