With the current firmware (didn’t happen in various versions before), the laser won’t turn off while traveling to a new area. It simply stays active engraving a line across the entire travel path.
Is that a bug?
Is that a bug?
Ensure you’re on the latest firmware, 1.17.17 and using the latest Luban 4.9.1. There was a background change on both, and when not matched up, will cause transient lines when the laser should be off. I would suggest manually updating via USB on the machine.
Will try, thanks for the fast respone.
Yeah found out expert me didn’t install the latest firmware, as it just stated “20&40W laser support” and apparently I thought “naah I’ll do to later, I don’t own any of these”…yeah…thanks again ![]()
Glad to hear, simple mistakes catch us all.
Least it was an easy fix.
they still popping up hey
