I own an A350 with the original 1.6watt laser. I haven’t used my laser in awhile, so when I updated from V.1.12 to the new firmware I didn’t think anything of it. Since then, at every stage of trying to engrave a photo I have had issues.
The first issue is that I’ve never really gotten the auto-focus to work. It ALWAYS fails, so I manually set the height to roughly 6mm above the surface I’m engraving. Otherwise, the auto-focus tries to set the height to roughly 76mm above the surface. Not a big deal here as I have consistently been able to engrave by manually setting the height but this issue has never been resolved.
The second issue is that I usually can send prints/engravings over wifi but for whatever reason this fails often and I need to disconnect my machine from Luban and reconnect and try again. Often, I will just use a USB stick because I’m impatient at trying to get the wifi to take the file.
The third and main issue is the real reason I am posting this. I am having an issue with the laser not completing this engraving. It stops at 77 percent and says it is complete. I have tried remaking the file in Luban and updating the firmware to the latest but still having problems.
Has anyone else had this issue?
Laser Photo
Original Photo
