Print file management?
Ok, noob here.
I just got my A350 on Christmas eve, got it all set up for 3d Printing. Tried doing the vase, 1st attempt was a total failure. I hadn’t calibrated properly, got that figured out, and also updated the firmware via USB thumb drive. Printed the vase, came out just fine! I then printed out a screw gauge from ThingVerse, all good there too.
I am having issues printing from WIFI with luban, so I have tried several things. Some times the file will transfer to the machine, sometimes it only sends part of the file. I have taken to just saving the g-code to the thumb drive and walking it to the machine.
This leads to my noob question. When I use the touch screen to open the USB files and select one to print it copies the file over to the machine. I now have several bad files there. How do I delete them from the memory of the machine?
Hi Mike,
New myself (have had it for exactly 1 week!). I just discovered how to erase old files:
  1. Swipe left on the control to access the menu (Files, Controls, Settings, etc).
  2. Click files
  3. Click the vertical ellipsis (3 dots) in the upper right.
  4. Select Edit
  5. You can now select all the files you want to delete and hit the little trash can at the bottom.
Cheers!
Individual files you can just swipe left to delete.
