Hi.
I want to calibrate step by step my SnapMaker 2.0 (A-350) to improve the printing quality. Now I have seen that many people suggest to run a PID autocalibration.
But I am stuck cause I get “Thermal runaway errors” after starting the PID autocal.
Any Idea or should I skip the “PID Tuning” step?
Thanks,
Rainer
SM Firmware: latest with vers. 1.10.1
Command Line using Octoprint / over USB conn.
Steps I have done to start PID:
M106 (Start FAN 100% of Extruder)
Send: M106
Recv: ok
Send: M303 E0 S205 C8 (Start Calibration of E0 (should be Extruder); Testcycles = C8 (8 times), Prefered HotEnd Temp 205C (S205)
RESULT & ERROR MESSAGE:
Recv: PID Autotune start
Recv: new E target temp: 0
Recv: new B target temp: 0
Recv: Error:Heating failed, system stopped! Heater_ID: 0
Recv: thermal run away of hotend! temp: 27.30 / 0
Changing monitoring state from “Operational” to “Error: Heating failed, system stopped! Heater_ID: 0 - thermal run away of hotend! temp: 27.30 / 0”
Send: M112
Send: N3 M11234
Send: N4 M104 T0 S037
Send: N5 M140 S0*96
Changing monitoring state from “Error: Heating failed, system stopped! Heater_ID: 0 - thermal run away of hotend! temp: 27.30 / 0” to “Offline (Error: Heating failed, system stopped! Heater_ID: 0 - thermal run away of hotend! temp: 27.30 / 0)”
Connection closed, closing down monitor
My System Config (not tuned exept of e-steps already tuned) is:
M503:
Send: M503
Recv: G21 ; (mm)
Recv:
Recv: M200 D3.00
Recv: M200 D0
Recv: M92 X400.00 Y400.00 Z400.00 E237.67
Recv: M203 X150.00 Y150.00 Z50.00 E25.00
Recv: M201 X3000.00 Y3000.00 Z100.00 E10000.00
Recv: M204 P1000.00 R1000.00 T1000.00
Recv: M205 B20000.00 S0.00 T0.00 J0.02
Recv: M206 X-19.00 Y-10.00 Z0.00
Recv: M420 S0 Z0.00
Recv: G29 W I0 J0 Z5.84500
Recv: G29 W I1 J0 Z5.98625
Recv: G29 W I2 J0 Z6.13125
Recv: G29 W I3 J0 Z6.21625
Recv: G29 W I0 J1 Z6.01750
Recv: G29 W I1 J1 Z6.16250
Recv: G29 W I2 J1 Z6.26250
Recv: G29 W I3 J1 Z6.26500
Recv: G29 W I0 J2 Z6.16000
Recv: G29 W I1 J2 Z6.21375
Recv: G29 W I2 J2 Z6.24000
Recv: G29 W I3 J2 Z6.26250
Recv: G29 W I0 J3 Z6.24750
Recv: G29 W I1 J3 Z6.22000
Recv: G29 W I2 J3 Z6.27625
Recv: G29 W I3 J3 Z6.39000
Recv: M301 P13.00 I0.10 D17.00
Recv: M851 Z1.00
Recv: M900 K0.22
Recv: M603 L0.00 U60.00
Recv: ok
