I connected to the SM via wifi, then loaded my file. But the only option on the touchscreen is “disconnect”. Do I have to disconnect it to run the program?
There are 3 ways to print/engrave/cnc:
- Upload via wifi
- Save gcode to usb thumbdrive
- Run the job directly by Luban with the play button
Obviously you didn´t load or ran the code to the machine.
If i upload my gcode trough wifi, i could select “print now”, then it disconnects from wifi automatically.
Hope this helps!
@rick52 Once you transfer the file via Wi-Fi, the file will be stored in the local memory of the screen. So you can disconnect it and start print via the touchscreen.
Best
