Hi all, you will find a collection of questions/issues including their corresponding solutions that have been brought up on the forum in this thread and you can use it as a guide to those questions. This thread is specifically for the Snapmaker Original, and its library will be expanded as more questions are asked. Thanks to anyone that has contributed in posting and answering the question threads!
Sorted by Alphabetical Order:
3D Printing
Hot end, laser and CNC module running at full powerful at all times: https://forum.snapmaker.com/t/runaway-overheating-of-hotend
Snapmaker Original stringing oozing issue within printed alphabet: https://forum.snapmaker.com/t/snapmaker-original-stringing-oozing-issue-within-printed-alphabet
Laser Engraving/Cutting
Cut plastic: https://forum.snapmaker.com/t/need-help-to-cut-plastic
Machine
Adding TL-Smoothers to server motors: https://forum.snapmaker.com/t/anyone-add-tl-smoother-to-their-servo-motors-sm1
How to print after transferring files over Wifi: https://forum.snapmaker.com/t/once-the-sm-is-connected-over-wifi-the-only-option-is-disconnect
Post-processor for Vectric`s Aspire CNC: https://forum.snapmaker.com/t/i-need-a-post-processor-config-file-pp-extension-for-vectrics-aspire-cnc-program
USB compatibility issue: https://forum.snapmaker.com/t/can-i-pause-and-restart-3d-printing
DIY Projects:
Custom Aluminum Bed (CNC Project): https://forum.snapmaker.com/t/new-aluminium-bed-for-sm1-cnc-project
