I am looking at Luban 4.13.0. Is there any way to change the nozzle size in Luban other than manually editing the configuration file, ie “extruder_0.def.json” for the Dual extruder left nozzle?
Are you using the dual Extruder?
On top right click on the filament setup, change from Material settings to chose device and there you can edit the nozzle size (for the dual Extruder, idk If it is also working for single Extruder that way).
Thank you, I figured there was a way, I just wasn’t seeing it.
yeah, I dont get why they didnt add that to the “settings / machine settings” menu. I think all users go there first.
