Hello,
Have you tried to select a different Nozzle size in Luban?
There is a choice of .2, .4, .6 but I can’t figure out what other settings are changed when selecting a different one?
Thanks
Hello,
Thanks
You are better off using Cura as there are specific settings for different size nozzles. Luban only does the 0.4 but uses Cura at its core.
Hi, the choice of nozzle scale just affects the control extraction amount and won’t change the settings display on Luban. If you use a 0.4 mm nozzle but choose .6 scale, the extraction flow will be larger and may cause jam to your 0.4 mm nozzle.
