Nozzle replacement
I have been searching for the E3D V6 Nozzle replacement on aliexpress and taobao. Realised that V6 is more common with the hat. Seems like the “slim” V6 is not very common? Or am I searching for the wrong nozzle for my snapmaker 2.0 A350? Can I use a Mk8 nozzle?
I believe the Snapmaker hot ends all use MK8 nozzles. I know the dual extrusion module does, albeit in a smaller diameter tip. The threads are the same and I’m using MK8 Diamondback nozzles with my Artisan’s dual extrusion module.
I have always used MK8 Nozzles as well.
Is that for the single extrusion unit? Mine is the single extrusion unit from Jan 2020.
Yes, both the single extruder and dual extruder print head modules use Mk8 nozzles.
Thanks. Have order Mk8 and will try. When replacing the Mk8 nozzle, after tightening the nozzle while heated (200C) do I need to realign the bed level sensor?
You wont need to re-align the sensor, just put it back about where it came from.
You will need to re-calibrate the machine and re-set the Z offset.
