Nozzle Replacement Option
Just wondering if the following nozzle will fit the Snapmaker A350?
Genuine E3D V6 Plated Copper Nozzle 1.75mm x 0.40mm (V6-NOZZLE-COP-175-400)
If the above nozzle doesn’t work does anyone know of a similar nozzle that will work with the Snapmaker A350?
The Snapmaker is MK8
Based on this, I’d think it would work: MK6 Vs MK8 Vs MK10 Vs E3D V6 - Differences & Compatibility - 3D Printerly
You wouldn’t have to move the switch, per se, but you would have to recalibrate your to accommodate your change in Z height
Can i confirm that Snapmaker 2.0 A350’s 3D hotend is using Mk8 and not E3D-V6 (slim)? I have been getting different inputs…
