You’re missing a Y module at startup. Check your connections. If you can’t make it work contact support.
233510,1970.01.01 00:03:53.510,INFO,SC-FW,Scanning modules ...
235483,1970.01.01 00:03:55.483,ERROR,SC-FW,No module on CAN1!
236485,1970.01.01 00:03:56.485,INFO,SC-FW,New Module: 0x203BBA00
236514,1970.01.01 00:03:56.514,INFO,SC-FW,Got axis X, endstop: 0
236534,1970.01.01 00:03:56.534,INFO,SC-FW,length: 356 mm, lead: 8 mm
236547,1970.01.01 00:03:56.547,INFO,SC-FW,Function [ 0] <-> Message [ 3]
236551,1970.01.01 00:03:56.551,INFO,SC-FW,New Module: 0x203BB9A6
236614,1970.01.01 00:03:56.614,INFO,SC-FW,Got axis Z, endstop: 0
236634,1970.01.01 00:03:56.634,INFO,SC-FW,length: 356 mm, lead: 8 mm
236647,1970.01.01 00:03:56.647,INFO,SC-FW,Function [ 0] <-> Message [ 4]
236649,1970.01.01 00:03:56.649,INFO,SC-FW,New Module: 0x2001AB3C
236671,1970.01.01 00:03:56.671,INFO,SC-FW,Got toolhead 3DP!
236695,1970.01.01 00:03:56.695,INFO,SC-FW,Function [ 8] <-> Message [ 18]
236697,1970.01.01 00:03:56.697,INFO,SC-FW,Function [ 9] <-> Message [ 19]
236701,1970.01.01 00:03:56.701,INFO,SC-FW,Function [ 6] <-> Message [ 20]
236704,1970.01.01 00:03:56.704,INFO,SC-FW,Function [ 7] <-> Message [ 21]
236712,1970.01.01 00:03:56.712,INFO,SC-FW,Function [ 1] <-> Message [ 5]
236715,1970.01.01 00:03:56.715,INFO,SC-FW,Function [ 10] <-> Message [ 22]
236719,1970.01.01 00:03:56.719,INFO,SC-FW,Function [ 2] <-> Message [ 6]
236722,1970.01.01 00:03:56.722,INFO,SC-FW,Function [ 16] <-> Message [ 23]
236725,1970.01.01 00:03:56.725,INFO,SC-FW,probe: 0x1, filament: 0x1
236729,1970.01.01 00:03:56.729,INFO,SC-FW,New Module: 0x203BB0EE
236743,1970.01.01 00:03:56.743,INFO,SC-FW,Got axis Y, endstop: 0
236762,1970.01.01 00:03:56.762,INFO,SC-FW,length: 356 mm, lead: 8 mm
236777,1970.01.01 00:03:56.777,INFO,SC-FW,Function [ 0] <-> Message [ 7]
236781,1970.01.01 00:03:56.781,INFO,SC-FW,New Module: 0x203BB984
236842,1970.01.01 00:03:56.842,INFO,SC-FW,Got axis Z, endstop: 0
236865,1970.01.01 00:03:56.865,INFO,SC-FW,length: 356 mm, lead: 8 mm
236877,1970.01.01 00:03:56.877,INFO,SC-FW,Function [ 0] <-> Message [ 8]
236882,1970.01.01 00:03:56.882,INFO,SC-FW,Model: unknow
237180,1970.01.01 00:03:57.180,ERROR,SC-FW,Cannot detect any Linear Module!
It works on prior firmware because it doesn’t verify to see if all the modules are installed properly. But, it also means your endstop won’t work reliably. This should get fixed, likely with a replacement module by support.
