No usb connection
Last week I got finally my SM A350 printer. The first testprint via wifi worked quit well. After that I tried to establish the usb-connection. It failed completely. After installing the CH340 driver, there is even no beep when I pug in the usb-connector. The device is simply not detected (window 10, device manager). I tried this on two different computers and tow different usb-cables. I even tried with a raspberry-octoprint. Usb-sticks are working flawlessly.
Do you see a com port in luban? Maybe you have to refresh several times. In my case it worked after unplugging and replugging whilst printer and Windows are running.
Are you using the micro USB port on the controller?
My mistake and problem solved! Thanks a lot!!!
