I cannot cut out a text by laser with Luban. After processing it is a striped black and white image, not an outline text. With SnapmakerJS it was easily to choose vector image. SnapmakerLuban:
SnapmakerJS:
in the edit tab, turn off the “fill” option, that should let it switch to an outline. though i strongly recommend using something like Inscape to create the text outline as an SVG for cutting. you will get better results that way.
But where can I find that Fill option in Luban?? (Yes, I prefer Inkscape, but this extra step shouldn’t be necessary for a simple letter.)
i dont have luban on this computer so i cant show snips, but at the top if you select the “edit” tab
then with the text selected, in the window on the right, you should see a checkbox that says “fill”.
Solved in Luban v3.12.3. Thank you.
