Is it normal after burning with the laser for the pattern to be visible on the platform? This is what the platform looks like after cutting the sample box.
Yes.
Wipe down with rubbing/isopropyl alcohol if you want.
Will remove any residue.
There will always be discoloring with laser operation but it’s nothing to worry about.
Another thing i just noticed:
Have you already remounted your Y-rails? If not i’d recommend to do so. Looks like they are shifted to the back by one hole, the way those rails are attached to the base might give you quite some trouble.
Thank you for pointing this out! Time for some re-assembly…
Its amazing how many times that happens, the diagram in the book is a little confusing i think because of the angle it shows or something.
