New linear modules
Good day
Installed my new linear modules today firmware updated unfortunately no response touchscreen works well but no response from the Y Z rail does not go to home position.
(The previous modules there everything worked perfectly).
What struck me was that 4 of the modules went very heavy when I slid them in the right place.
The cables are in the right place as with the old modules.
what’s wrong??
m.vr .gr W.Labree
The new modules are marked 8mm (2 off) or 20mm (3 off) lead. Did you make sure you installed them on the correct axes?
Hello.
I didn’t know there was a difference, nor is it stated on the letter that came with it.
This is what I did.
Y 2x 80 mm Z 2x 20m X 1x 20 mm is this wrong ?
Glad you responded.
@ Barracuda,
Here are the instructions from the original description of the A350T.
Here the pictures of the axles to be used and their position !!!
Y-Achse Lead 20 mm axles
Z-Achse Lead 08 mm axles
X-Achse Lead 20 mm axle
Top dude.
That’s obviously great that you helped.
So I didn’t look closely
Kind regards William
You’re welcome,
glad I could help !!
With kind Regards Reiner
