has anybody tried to do multicolor prints with the SM2? I did today but faced some issues like the nozzle and the heatbed lost temperature and i had to get them back on temperature before i was able to change filament. I am slicing with S3D and use the variable settings wizard to split the processes.
Does anybody have an idea how to tweak the start and/or the end G-code that multicolor prints are easier to handle?
I have not tried it but give M600 a try at your desired Color change spot. It should pause the print and hold the temps or at least it does on my Prusa machines.
I have to take that back. I tried M600 and it sort of worked. It requires the print heat to be up to printing heat and then it did a retract of the filament. I switched the Touch Screen to print head heat and it let me reload the filament but then it got in some mode where it was stuck. I entered the M600 on the console so Im guessing it was expecting some kind of input to continue. It just said “waiting for user input”. SO there is some hope if we can get the right syntax on the command.
