Snapmaker 2.0 still ignoring M600 command, please HELP!!
I created a simple 10x10x10 block to test the m600 command and it worked. But then on a complex print, m600 is ignored. I’ve wasted 2 pounds of filament trying to figure this problem out. I’m losing my mind, I need help.
Which toolhead?
May share your gcode?
Did you manipulate manual or did it the slicer for you?
This worked for me. Use a text editor to edit the .gcode file. Go through and place M76 on it’s own line at the lines of gcode where you need a pause. If you used PrusaSlicer and set a color change at the layers you needed, then it’s simpler. Using the text editor, “Find” all of the M600 commands and place M76 on the next line, on it’s own, after every M600 command or just replace the M600 with M76. Either way, the print will pause and the toolhead will park. You must manually replace your filament then resume the print.
It was cool working the problem because it brought me back to my days of DOS 1.1 and programming in BASIC. (Beginners Allpurpose Symbolic Instruction Code) 1984 was a long time ago and George Orwell was running late.
I’m still trying to figure out how to use both of my extruders. PrusaSlicer is generating bad code when employing both extruders. It causes file parsing to fail.
You will find this useful:
https://wiki.snapmaker.com/en/Snapmaker_Luban/manual/2_supported_gcode_references
@raypfountz This works but it does not initiate a filament change sequence?
