Today i played a bit with my new printer and tested the same STL twice.
One time sliced with Cura, the other time with Luban.
i was trying to use the same settings on both , even if some are not available in both slicers. But the majority were the same. In both slicers i had enabled ironing for a better surface. A difference i have recognized later is the number of perimeters for the outer wall.
What i have experienced is that the luban sliced file took significantly longer than the Cura file, even if both reported the same estimated time.
This is printed with Luban GCODE:
And this is the print from the Cura GCODE:
(Note: The dot between the 1 and the 7 is missing in the Luban print, because it did not stick)
If someone is wondering, what it is:
These are stitch markers which support you while knitting.
Original size is 24 x 15 mm. If someone is interested in the STL, i can share it.
