Luban svg not opening files at scale
Hello,
Since upgrading to 3.9.0, when I open a svg file, the dimensions don’t match inkspace dimensions anymore.
Have you noticed this?
Thanks
Hello,
Another problem that I have found in 3.9 concerns the supports; they are simply not created. I have tried with 3 different .stl without results.
At least not in the preview. (I have not tried to print these G-Codes)
Anyone else noticed this? or am I making a mistake somewhere?
Have a good day.
Yes, I’ve had the same issue. This is definitely a change/bug from 3.8 to 3.9. I imported an svg from inkscape that was 120x160 and it pulls it in at about 1/10th the size.
Same here. Just started with 3.9.0.
