Laser Cut files shrinking on Luban
It looks like this bug is back. I was using Luban fine, and now all my files are shrinking. I exported as SVG using Inkscape and Illustrator and tried PNG, and all the options I could think of were not working. Any special way we need to export/save the file? I used mm, and inches, and tried to scale on Luban but nothing looked correct. It has been a few hours already. Thanks for any tip you can give.
PS: everything is up to date. 10W laser
This happens to me if the SVG file is nearly the maximum workspace size. Usually leaving a few millimetres in the SVG’s document size compared to the maximum theoretically possible solves this for me.
Thanks. I tried the suggestion in Illustrator and Inskape, saving it as SVG Inskape and Plain. None worked. I see there was a bug in the past: .svg Files imported from InkScape have the wrong size. · Issue #502 · Snapmaker/Luban · GitHub. I also tried pixel and mm, creating a new file with just a square, but they are still small. :frowning:
