What is the default extrusion width in luban
what is the default width in Luban ?
can we change it mannually ?
thanks
Hi!,ijenchen
Your first post on the forum!
On Snapmaker Luban the standard extrusion is 0.4mm nozzle hole diameter.
You can change it manually, but you may want to use Ultimaker Cura instead of Luban.
I’ve only used the standard nozzle of 0.4mm, so I haven’t changed nozzles before, so I can’t help you.
There are several threads about using narrower or wider nozzles with a lot of recommendations. Search the forums for “0.2mm nozzle” or “0.8mm nozzle”.
Luban will not let you change the nozzle width, so you will have to use to a different slicer.
